lenovo nm-f331 bios
  • sertac545454
    • Jan 2019
    • 5
    • Türkiye
    lenovo nm-f331 bios
    lenova nm-f331 rev 1.0 I need bios file??
  • hoaca388
    Badcaps
    • Jan 2022
    • 12513
    Here : https://www.badcaps.net/forum/troubl...before-posting
    • ndher86
      • Aug 2016
      • 40
      • Indonesia
      TRY BIOS Lenovo LCFC KS485 KS585 KS686 KN580 NM-F331
      • ujhazi
        • Jul 2024
        • 17
        HI
        I have the same motherboard in a different lenovo16iru8 with bios password. I have tried to write the two bios chip with the file from above and they worked perfectly. May I ask someone to remove the password from the original files.?
        sn; PF4KDMMK
        Many thanks
        And 2 further question:
        1, I have a very similar Lenovo/15amn7/ with 1 bios and one ene chip and off course with "system password". If I have no socket to program the EC chip then I have no chance to remove the password?
        2, If a Lenovo has a onboard memory there is a tool which disables them if they are faulty, Is there any tool for disabling onboard hard disk. If I just remove it then it pops up in the device manager with yellow triangle.
        thanks
        • shiyab
          • Sep 2023
          • 1749
          • india
          Originally posted by ujhazi
          HI
          sn; PF4KDMMK
          Many thanks
          thanks
          hi
          • ujhazi
            • Jul 2024
            • 17
            Originally posted by shiyab
            hi
            Thanks, I have tried it. So the bigger file is double sized as it should be. 32mb instead of 16. Looks like to me the second half is a copy of the first half. I have tried to half the file and I write the half of it onto the chip, but it is not working. Flashing 11 long then switches off. Could you half the file for me?
            • bel77
              • May 2013
              • 34
              • jordan
              TESTTED OK
              and this orginal i3 mainboard tested
              • rmosh77
                • 4
                • Jordan
                thanks
                • Sailman
                  • Aug 2020
                  • 12
                  • Alaska
                  Hello Gentlemen
                  Lenovo NM_F331_REV 1.0 bios problem 11 blink
                  here is the original Files
                  Can you help?
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12513
                    Originally posted by Sailman
                    Hello Gentlemen
                    Can you help?
                    You MUST:
                    • Read BIOS guides, methods, resources and tools
                    • Try the method at BIOS guides, methods, resources and tools before requesting help
                    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                    • Use search function in case someone already answered your request
                    • Post under a related thread if it exists
                    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                    • Name your thread with make, full model numbers and request
                    • Provide a BIOS/EC dump if possible
                    • Attach files directly to your post instead of linking to external websites
                    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                    • Sailman
                      • Aug 2020
                      • 12
                      • Alaska
                      Hello Gentlemen
                      Can you help?
                      Model number: ideapad slim 3 15IRU8
                      Serial number: PF54MWYQ
                      • peste
                        • Dec 2016
                        • 14035
                        • ROMANIA
                        bios extracted from Lenovo website update for IdeaPad Slim 3 15IRU8 - Type 82X7
                        DMI 42000 - 43FFF DMI in 16MB bios...
                        • Sailman
                          • Aug 2020
                          • 12
                          • Alaska
                          it works , Thank you Brother
                          • ub6ib969
                            • Jul 2010
                            • 201
                            Serial Number - PF4SKCYC
                            thanks in advance
                            • peste
                              • Dec 2016
                              • 14035
                              • ROMANIA
                              thanks in advance
                              two posts up you have what you need...just don't shout...
                              • ub6ib969
                                • Jul 2010
                                • 201
                                can the serial number inserted into to newly generated bios ? thnx
                                • peste
                                  • Dec 2016
                                  • 14035
                                  • ROMANIA
                                  the bios from post #12 is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
                                  select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
                                  • ub6ib969
                                    • Jul 2010
                                    • 201
                                    ok will try however can someone please provide a bios with cleanme, update was applied however the unit now turns on but caps lock key and num lk key on, fan spins.
                                      • 22415
                                      The virgin bios has clean configured firmware.
                                      • ub6ib969
                                        • Jul 2010
                                        • 201
                                        so if the issue was the bios and flashed using the files uploaded by peste it should boot up ? I used the HXD editor and compared both bios and there are difference but i have no idea what i am looking at and what to copy over to the virgin file 🤔 i am afard ti copy over he invaild entries causing the issue.
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • maanee11
                                          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                                          by maanee11
                                          Hello Everyone,
                                          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                                          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                                          In the website, you can only see specs etc.
                                          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                                          11-08-2025, 04:08 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
