lenovo nm-f331 bios
NEED BIOS PLEASE
OLD BIOS ATTACHED
LENOVO IDEAPAD SLIM 3 I5IAH8
SN: PF54LRAX
Attached Filesif you find these attachements useful please consider making a small donation to the site
IdeaPad Slim 3 15IAH8 - Type 83ER
https://www.badcaps.net/donateComment
Hello, can you fix this bios, power on, keyboard light, no display.
Lenovo KS485/KS685 NM-F331 Rev 1.0
Model : ideapad slim 3 15IRU8
S/N: PF4P3WZP
Thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
You model type is 82X7
Forum search: https://www.badcaps.net/search?q=3+1...3+15IRU8%22%7D
Virgin bios ,flash both.
https://www.badcaps.net/forum/troubl...81#post3669481
Copy the DMI from your 16MB backup to the new 16MB bios with a hex editor with the offsets 42000 - 43FFFComment
Can you please do if for me? I try follow the step instruction with Tiny Hex but lost in the process...
My back up bios is above.
ThanksComment
biosAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello, can someone Add Dmi info on this bios ?
The new bios I got power on the laptop, keyboard light, fan spin fast, no display.
Can you retrieve the Dmi info from my old bios and put it on the new one , I tried but failed to do it.
S/N: PF4P3WZP
I added the DMI to the 16MB bios - https://www.badcaps.net/forum/troubl...85#post3732185Hello, can someone Add Dmi info on this bios ?
S/N: PF4P3WZP
Thank you
Assuming you did flash both as suggested https://www.badcaps.net/forum/troubl...47#post3731347 then it should be working if there are no hardware problems.Comment
Try this biosAttached Filesif you find these attachements useful please consider making a small donation to the site
Good day
Kindly help fix bios for
Lenovo ideapad Pro 5 16 IMH9
serial #: PF4TNCYHAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
BIOS Lenovo LCFC KS485 KS585 KS686 KN580 NM-F331
