lenova nm-f331bios
NEED BIOS PLEASE
OLD BIOS ATTACHED
LENOVO IDEAPAD SLIM 3 I5IAH8
SN: PF54LRAX
Attached Filesif you find these attachements useful please consider making a small donation to the site
IdeaPad Slim 3 15IAH8 - Type 83ER
https://www.badcaps.net/donateComment
Hello, can you fix this bios, power on, keyboard light, no display.
Lenovo KS485/KS685 NM-F331 Rev 1.0
Model : ideapad slim 3 15IRU8
S/N: PF4P3WZP
Thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
You model type is 82X7
Forum search: https://www.badcaps.net/search?q=3+1...3+15IRU8%22%7D
Virgin bios ,flash both.
https://www.badcaps.net/forum/troubl...81#post3669481
Copy the DMI from your 16MB backup to the new 16MB bios with a hex editor with the offsets 42000 - 43FFFComment
Can you please do if for me? I try follow the step instruction with Tiny Hex but lost in the process...
My back up bios is above.
ThanksComment
biosAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello, can someone Add Dmi info on this bios ?
The new bios I got power on the laptop, keyboard light, fan spin fast, no display.
Can you retrieve the Dmi info from my old bios and put it on the new one , I tried but failed to do it.
S/N: PF4P3WZP
I added the DMI to the 16MB bios - https://www.badcaps.net/forum/troubl...85#post3732185Hello, can someone Add Dmi info on this bios ?
S/N: PF4P3WZP
Thank you
Assuming you did flash both as suggested https://www.badcaps.net/forum/troubl...47#post3731347 then it should be working if there are no hardware problems.Comment
Try this biosAttached Filesif you find these attachements useful please consider making a small donation to the site
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
BIOS Lenovo LCFC KS485 KS585 KS686 KN580 NM-F331
