lenova nm-f331bios
NEED BIOS PLEASE
OLD BIOS ATTACHED
LENOVO IDEAPAD SLIM 3 I5IAH8
SN: PF54LRAX
Attached FilesComment
IdeaPad Slim 3 15IAH8 - Type 83ER
Attached Files↵
https://www.badcaps.net/donateComment
Hello, can you fix this bios, power on, keyboard light, no display.
Lenovo KS485/KS685 NM-F331 Rev 1.0
Model : ideapad slim 3 15IRU8
S/N: PF4P3WZP
Thank youAttached FilesComment
You model type is 82X7
Forum search: https://www.badcaps.net/search?q=3+1...3+15IRU8%22%7D
Virgin bios ,flash both.
https://www.badcaps.net/forum/troubl...81#post3669481
Copy the DMI from your 16MB backup to the new 16MB bios with a hex editor with the offsets 42000 - 43FFFComment
Can you please do if for me? I try follow the step instruction with Tiny Hex but lost in the process...
My back up bios is above.
ThanksComment
biosAttached FilesComment
Hello, can someone Add Dmi info on this bios ?
The new bios I got power on the laptop, keyboard light, fan spin fast, no display.
Can you retrieve the Dmi info from my old bios and put it on the new one , I tried but failed to do it.
S/N: PF4P3WZP
Thank youComment
I added the DMI to the 16MB bios - https://www.badcaps.net/forum/troubl...85#post3732185Hello, can someone Add Dmi info on this bios ?
S/N: PF4P3WZP
Thank you
Assuming you did flash both as suggested https://www.badcaps.net/forum/troubl...47#post3731347 then it should be working if there are no hardware problems.Comment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by maanee11Hello Everyone,
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
- Loading...
BIOS Lenovo LCFC KS485 KS585 KS686 KN580 NM-F331
