lenova nm-f331bios
  • clearPC
    • Feb 2017
    • 12
    • Poland
    Originally posted by ndher86
    TRY BIOS Lenovo LCFC KS485 KS585 KS686 KN580 NM-F331
    Hello. Could you add it again?
    • chiptech
      • Apr 2017
      • 17
      • india
      NEED BIOS PLEASE
      OLD BIOS ATTACHED
      LENOVO IDEAPAD SLIM 3 I5IAH8
      SN: PF54LRAX
      • hoaca388
        Badcaps
        • Jan 2022
        • 12421
        Originally posted by chiptech
        NEED BIOS PLEASE
        OLD BIOS ATTACHED
        SN: PF54LRAX
        IdeaPad Slim 3 15IAH8 - Type 83ER
        • BOGOSY77
          • Aug 2018
          • 59
          • PITON
          Hello, can you fix this bios, power on, keyboard light, no display.
          Lenovo KS485/KS685 NM-F331 Rev 1.0
          Model : ideapad slim 3 15IRU8
          S/N: PF4P3WZP
          Thank you
            • 22135
            S/N: PF4P3WZP
            Thank you
            You model type is 82X7
            Forum search: https://www.badcaps.net/search?q=3+1...3+15IRU8%22%7D
            Virgin bios ,flash both.
            https://www.badcaps.net/forum/troubl...81#post3669481
            Copy the DMI from your 16MB backup to the new 16MB bios with a hex editor with the offsets 42000 - 43FFF
            • BOGOSY77
              • Aug 2018
              • 59
              • PITON
              #26
              Can you please do if for me? I try follow the step instruction with Tiny Hex but lost in the process...
              My back up bios is above.
                • 22135
                bios
                • BOGOSY77
                  • Aug 2018
                  • 59
                  • PITON
                  #28
                  bios
                  ON AND OFF, ON AND OFF, NO DISPLAY, NO KB LIGHT UP
                  • BOGOSY77
                    • Aug 2018
                    • 59
                    • PITON
                    #29
                    Hello, can someone Add Dmi info on this bios ?
                    The new bios I got power on the laptop, keyboard light, fan spin fast, no display.
                    Can you retrieve the Dmi info from my old bios and put it on the new one , I tried but failed to do it.
                    S/N: PF4P3WZP
                    Thank you
                      • 22135
                      S/N: PF4P3WZP
                      Thank you
                      I added the DMI to the 16MB bios - https://www.badcaps.net/forum/troubl...85#post3732185
                      Assuming you did flash both as suggested https://www.badcaps.net/forum/troubl...47#post3731347 then it should be working if there are no hardware problems.
                      • almussafer
                        • Jun 2019
                        • 86
                        • Iraq
                        #31
                        Try this bios
                        • to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                          by to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                          I have opened the laptop and identified the main BIOS chip...
                          10-24-2025, 01:35 AM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
                        • maanee11
                          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                          by maanee11
                          Hello Everyone,
                          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                          In the website, you can only see specs etc.
                          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                          11-08-2025, 04:08 AM
                        • m1ch43lzm
                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                          by m1ch43lzm
                          Hi everyone
                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                          There's also an extra OTP Secu.R...
                          09-06-2025, 05:47 PM
                        • Forest79
                          by Forest79
                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                          07-23-2023, 07:39 AM
