Bios repair Lenovo NM-D711 rev 2.0
Every donation made will go towards server fees and maintenance costs.Comment
Thanks! I wiil try it!you have everything you need at post #2...
https://www.badcaps.net/forum/troubl...6h#post3319736Comment
Hi if someone can help i would appreciate very much! My client Lenovo it turns on, charges the battery and light up the keyboard but has black screen.
Cant find any short, tested with other Ram, same thing, i suspect BIOS
Dumps and info below:
Legion 5 Pro-16ITH6H Type 82JD
NM-D711 Rev 1
S/N - PF3D0HMKAttached Filesif you find these attachements useful please consider making a small donation to the site
Legion 5 Pro-16ITH6H Laptop (Lenovo) - Type 82JDHi if someone can help i would appreciate very much! My client Lenovo it turns on, charges the battery and light up the keyboard but has black screen.
NM-D711 Rev 1
S/N - PF3D0HMK
https://www.badcaps.net/donateComment
SN : PF33CPJV
H1CN##WW
Hello guys,
Could anyone share the working BIOS (16MB+DMI)?
All hardware part without any issue, black screen with keyboard led light up but the both CAPS BLOCK AND NUM lock not working.
Have tried BIOS provided in other post not working in my case.
Appreciate for any advice, thanks!
https://www.badcaps.net/forum/troubl...6h#post1827525
https://www.badcaps.net/forum/troubl...-5-pro-16ith6h
https://www.badcaps.net/forum/troubl...6h#post1852352Comment
post motherboard model, TYPE,etc.Legion 5 Pro-16ITH6H
SN : PF33CPJV
H1CN##WW
Hello guys,
post the contents of the bios chip even if it is corrupted..
read the forum rules..
https://www.badcaps.net/forum/troubl...ore-postingDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
I am so sorry about it.
If someone can help i would appreciate very much!
S/N : PF33CPJV
Motherboard Model: NM-D711 Rev 2
S/N : PF33CPJV
You don't need to try the bios anymore, move on to finding hardware problems.↵
My device is a Lenovo Legion 5i Pro (2021) 82JD
Model Number: 16ITH6H
Board: NM-D711 Rev 2.0
Bios Version: H1CN57WW
Lenovo Serial Number: PF33CPWC
Sometimes Bios does not POST. Started happening after I force shutdown my laptop after switching from dGPU to IGPU
Checked both IGPU and DGPU whenever the BIOS Posted and saw that it all works correctly (Including the RAM and Storage). Looks like the bios is causing issues.
Can someone please provide a working version for the BIOS? I have uploaded the UB1/2 and UB3 bin backups from ASProgrammer.
Thank YouAttached Filesif you find these attachements useful please consider making a small donation to the site
you have everything you need at post #2...My device is a Lenovo Legion 5i Pro (2021) 82JD
Thank You
https://www.badcaps.net/forum/troubl...6h#post3319736Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
hi
there is a laptop that after bios update no display and no post just black screen .
i tested bios files from this forum but no different.
any help appreciated.
Model Legion 5 Pro-16ITH6H
SN: PF38JMAQ
Factory ID: JVHFC1
MO: PF9XB1A11183
MTM: 82JD003XAX
this is original dump.Attached Filesif you find these attachements useful please consider making a small donation to the site
.Today should be different from yesterday.Comment
try the post above..hi
SN: PF38JMAQ
Factory ID: JVHFC1
MO: PF9XB1A11183
MTM: 82JD003XAX
this is original dump.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
My laptop MB Number is NM-D711 REV:1.0
I test above post (https://www.badcaps.net/forum/troubl...6h#post3319736)
but no display yet.
Please check my org dump if it is fixable?.Today should be different from yesterday.Comment
hi ad. my laptop turn off while up bios.
it power but no display
model: legion 5 17ITH6H
SN:PF39F8FB
MO:PF9XB1C26062
MTM:82JM0024US
mn-d711
ps :I tried to upload the file on the forum, but there are still no images.
AD FIX BUILD HELP ME,PLEASE
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by riko 656Hello everyone,
I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
Laptop Model:- Model: Lenovo Legion Slim 5 16APH8
- GPU: NVIDIA GeForce RTX 4070
- Main BIOS chip size: 32MB
- VBIOS chip size: 16MB
What I Have Tried So Far:- I
11-04-2025, 05:14 AM -
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...09-12-2024, 02:30 PM
- Loading...
