BIOS for LENOVO LEGION 5 PRO 16ITH6H
  • gogunet
    • Dec 2018
    • ro
    S/N PF2RCD7F
    MTM 82JD000WRM
    The laptop won't start. It reads the power button, keyboard lights up, it charges, but no display.
    Need a working bios.
    Thanks!​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12392
    S/N PF2RCD7F
    MTM 82JD000WRM
    Thanks!​
    Post bios backup file.
    • LunarEklipze
      • May 2024
      I can't seem to flash a new BIOS normally with the .exe file provided by Lenovo, so I'm looking for help. Every time I try I get an error message that reads "New BIOS region (1000000h) does not match with current (C00000h)"
      I've extracted the .bin files from both the UB1/UB2 chip (8MB) and also from the UB3 chip (16MB) using a flash programmer although I am not sure if both need to be flashed or just one. Can I get help getting working .bin files from the latest BIOS version for each chip respectively to see if that works? I've extracted the bios.fd file myself and then converted to .bin and separated the file into a 16MB and a 8MB one but my efforts failed. I'm not sure where I messed up.
      I'll attach the bin files I extracted from each chip and the bios.fd file along with the same file but .bin from update H1CN57WW to see if that may be of some help. What does the serial number have to do with how the BIOS works?
      S/N: PF2JFPRM
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        Try
        • LunarEklipze
          • May 2024
          Thank you so much for the file. Unfortunately it did not work. I started having problems with my flash programmer saying it couldn't erase the chip, and then whenever it was successful in writing the file to the chip it would fail to verify. Right now all it does is the power button light turns on and off but nothing else happens. I even flashed the original files back but it's doing the same thing.
          There are some sellers that sell the bios chips with the bios programmed already. All I would have to do is replace the chips. I may have to go that route.
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            I think instead of buying a new chip and resold replace. You should go to professionals to fix that issue
            explain them you suspect a bios issue (if in your case its fail to update or any bios related error massage or if you sure its a bios issue) Dont take any risk
            • Palafox
              • Nov 2023
              • 9
              Having a very similar issue to this although the keyboard only lights up for a few seconds then turns off. What makes you suspect it was the bios chip that was faulty? Also did you end up resolving your issue? Thanks!
              • gogunet
                • Dec 2018
                • ro
                Unfortunately the CPU was dead 😢
                • elClemente
                  • Jan 2025
                  • Deutschland
                  S/N: PF3B52FQ
                  MTM: 82JD000XGE
                  The laptop won't start. It does something when you press the power button but after 20-30sec it just turns off again. Keyboard lights up, it charges (charging idicator light lights up), fans are running for a short time, but no display and no boot.
                  Find attached the UB1-2 and the UB3 dumps I pulled of the machine. I also added the pictures of the chips.
                  Thank you in advance!
                  Bios chips on my motherboard are:
                  UB1 UB2 Giga Device 25R64CSIG (GD25R64CSIG)
                  UB3 XMC QH128AHIG
                  I (so far) succesfully used the cheap CH341a programmer in auto detect and without 1.8V adapter, as those chips are 3V.
                  • peste
                    • 13718
                    • ROMANIA
                    S/N: PF3B52FQ
                    MTM: 82JD000XGE
                    UB3 XMC QH128AHIG
                    you have everything you need at post #2...
                    https://www.badcaps.net/forum/troubl...6h#post3319736
                    • elClemente
                      • Jan 2025
                      • Deutschland
                      Thanks! Unfortunetly this didn´t solve my problem. Laptop is still stuck, but this time in stays on all time. I realy have to long press the power button to shut it off. I am investigating this more in the next days.
                      • to5it0
                        by to5it0
                        10-24-2025, 01:35 AM
                      • nissimezra
                        Lenovo Legion 9 16IRX8 NM-B481 rev 1.0 bios bin file
                        by nissimezra
                        Device: Laptop
                        Brand: Lenovo
                        Model: Legion 9 16IRX8 - Type 83AG
                        Service Tag: PF4M4H2J
                        Board number: NM-B481 rev 1.0 bios bin file
                        Request: BIOS dump
                        Problem: Black screen
                        The bios chip is 25rh256cxiq , can I use winbound 25q256... instead ?
                        thanks in advanced...
                        05-29-2025, 04:07 PM
                      • Forest79
                        by Forest79
                        07-23-2023, 07:39 AM
                      • survivalbloke
                        Unable to extract bios file from Lenovo bios exectuable
                        by survivalbloke
                        I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                        Code:
                        "innoextract 7wcn38ww.exe"
                        it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                        The trouble I'm having is that I'm not getting the newly...
                        06-12-2024, 07:55 AM
                      • maanee11
                        Help to get Lenovo BIOS bin file for Thinkpad T560
                        by maanee11
                        Hello Everyone,
                        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                        05-15-2022, 11:59 AM
