MacBook Air 13 2014 - Remove EFI password
  • ritalo
    • Jun 2023
    • 12
    • France
    I have a MacBook Air 13 inches 2014.
    I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
    I know how to remove the password with a usb programmer.
    I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
    Then I have to find this value in the file : $SVS because it indicate where is the password.
    But I can't find the value.
    I have attached the file​
    Thank you if you can help me
  • mon2
    • Dec 2019
    • 14634
    You will need to move this thread to the BIOS forum. See above.
    • reformatt
      • Feb 2020
      • 1480
      https://www.badcaps.net/forum/troubl...ac-efi-toolkit
      • ritalo
        • Jun 2023
        • 12
        • France
        Thank you for the link.
        The software does not recognize my file
        Click image for larger versionName:	mefit-114-message.jpgViews:	0Size:	58.4 KBID:	3271182
        • kevingill
          • Jun 2013
          • 152
          • England
          That BIOS file doesn't look right. Can you try reading again and compare the two to make sure?
          • ritalo
            • Jun 2023
            • 12
            • France
            I read again and can open the file with MacEfiToolkit but still can't find $SVS in it
            • Blaze Tech
              Learner
              • 214
              • Ghana
              Kindly upload the file again
                • 21685
                What model is your programmer and the software version. Are you using a clip, how are you attaching the chip to the programmer
                • ritalo
                  • Jun 2023
                  • 12
                  • France
                  Here is the file
                  The usb programmer is GZUt EZP XPro V2 Usb Flash Writer
                  The software I use are GZUT_EZP_XPro 2.1 and WinHex 20.3 SR 5
                  I am not using a clip, I am attaching the chip by plugging the programmer on the connector on the motherboard.
                  • reformatt
                    • Feb 2020
                    • 1480
                    This is a bad dump, most of the info is missing. ​Should look like this in UEFI tool (this is from an old dump off an 820-3437 board).
                    Not sure about your programmer and using the header. I never use it as it's not exactly reliable and often corroded. Easier to just hot air U6100 off and read it directly on your programmer.
Name:	Screenshot 2024-05-15 223242.jpg
                      • 21685
                      Its an EZP**** programmer,piece of crap. He might be able to read it by slowing the speed down,it has an option to do that
                      • ritalo
                        • Jun 2023
                        • 12
                        • France
                        I cleaned all the connectors with electronic contact cleaner.
                        Now it works.
Name:	Capture d'écran 2024-05-15 185943.png
                        I have found the $SVS value in the file.
                        • ritalo
                          • Jun 2023
                          • 12
                          • France
                          Can you tell me if I have selected the correct part of the file and if I have to fill it with 00 or FF?
Name:	Capture d'écran 2024-05-15 191902.png
                          • kevingill
                            • Jun 2013
                            • 152
                            • England
                            You could use the Mac EFI Toolkit to remove the EFI password by clicking the padlock
                            • ritalo
                              • Jun 2023
                              • 12
                              • France
                              Thank you for your help
                              I have unlocked the EFI file with MacEfiToolkit
                              I have plugged the usb programmer to the motherboard and to the pc
                              I have plugged the power adapter to the MacBook
                              When I write the bin file to the EFI of the MacBook, it power up at least one time during the process and I have to power it down for the process to continue.
                              But the writing is not good because after it, the MacBook powers up but does not boot, there is no "Dong" at startup and the screen stays black.​
                              • reformatt
                                • Feb 2020
                                • 1480
                                You can't do it that way. Your programmer has to supply that power to the chip, and as it's in circuit it's unlikely to be able to do that (especially since it's an EZP programmer and it draws its power off a USB port). This is why you remove the chip off the board and place it directly into the programmer via a WSON8 programmer adaptor.
                                The only one I know that DOES work onboard is the CMZapper Medusa 2, but it's an expensive device. Cheaper to buy this adaptor, and just hot air the chip off the board.
                                https://www.aliexpress.com/item/1005...Cquery_from%3A
                                • kevingill
                                  • Jun 2013
                                  • 152
                                  • England
                                  I have successfully written the EFI using a similar method, but you may need to try with/without battery and/or power supply. If that fails, then certainly remove the EFI ROM with hot air and do it that way.
                                  • ritalo
                                    • Jun 2023
                                    • 12
                                    • France
                                    I have written the EFI with the power adapter and the battery. The MacBook does not power up during the process when both are plugged.
                                    But verification fails and the MacBook still does not boot.
                                    I will retry hoping it will work
                                    • wishes2022
                                      Panasonic CF-SR4 CF-SR4R remove bios password or extract .exe file
                                      by wishes2022
                                      can you please remove password of CF-SR4 or extract .exe file?...
                                      05-22-2025, 08:26 PM
                                    • mnciks11
                                      Kindly remove the password on this macbook bin file
                                      by mnciks11
                                      Hello my lovely brothers, i have attached the Macbook Pro Touchbar bin file, it got a password, i downloaded the cleaned file for this machine, programmed the chip, the password was removed but however, it does not load iOs, it only runs on windows due Me Region.
                                      Luckly i did the backup for this machine, i still have the locked file bin
                                      I believe the password can be removed within the file itself, i dont know how to do it by myself but im willing to learn..The file is attached...
                                      06-24-2020, 02:50 AM
                                    • snpetit
                                      Asus FA706IH Bios Password remove
                                      by snpetit
                                      i need some help :-/
                                      i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                      Could you please remove all password related stuff from this bios. A hate Asus....
                                      Thanks in advance!...
                                      01-10-2025, 09:17 AM
                                    • mferna14
                                      Password removal on MacBook Pro A2159
                                      by mferna14
                                      Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                                      05-13-2025, 04:16 PM
                                    • justice171
                                      Help needed | Remove Power-ON password on Proline V146GNK (SU_GN100_MB_V12_20231120A)
                                      by justice171
                                      Hi BadCaps team,
                                      I’m asking for a bit of community help with a Proline notebook that’s stuck with a Power-ON (BIOS) password. The laptop has very limited info available and I suspect it may be a local (South African) Proline board. Thought I’d check here in case anyone has seen this one before.
                                      What I have:
                                      • Model: Proline NoteBook V146GNK
                                      • Board: SU_GN100_MB_V12_20231120A
                                      • Serial: GN10Q12124205W1588
                                      • Notes: 12V main board. Very little documentation available.
                                      What I’d like to request:
                                      • Has anyone dealt with this Proline board before or seen matching BIOS/firmware
                                      10-10-2025, 09:41 PM
