bios asus fx570u
  • salah11
    • Apr 2016
    • 7
    • Algeria
    bios asus fx570u
    hello,
    need bios dump for asus fx570u
    attached the original bios,
    the computer run and enter bios, but not windows boot
    and the problem is that all the bios parameters are jamed
    thank you
    • 21692
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • salah11
      • Apr 2016
      • 7
      • Algeria
      hello
      need bios for asus
      Model : FX570UD-DM002T
      SN : J1N0CX171038049
      Board : (x570ud rev 2.0)
      thank you​
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • kenkaniff
        HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
        by kenkaniff
        Product Name: HP Pro x360 Fortis 11-inch G9
        System BIOS: U94 Ver.01.08.00 10/06/2023
        Serial Number: 5CG31946F5
        SKU Number: 85W05EC#AK8
        Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
        This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
        I needed to remove bios password...
        10-01-2025, 04:32 AM
      • gagarasta
        Operating system not found, cannot enter bios or boot to usb
        by gagarasta
        Hello everyone, I had issues on my laptop acer 4752G
        I'm using windows 10 until I decided to install windows 7 because of old hardware limitation, then I just found I cannot access my bios anymore. So far I already try these:
        1. On system information its uefi not bios/legacy
        2. Advanced restart but there's no uefi setting
        3. Try to reinstall my pc using fdd but cannot enter boot selection
        4. Press f2 f8 f10 only beep but straight into boot
        5. Try reflash bios using fdd fn key+esc+power not success
        6. Take the cmos battery off and...
        11-05-2023, 11:23 AM
      • lrouw84
        Asus vivobook s510ua bios changed to x510un
        by lrouw84
        Hi there,
        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
        01-28-2023, 01:31 PM
