Lenovo Golden Key V3.5.60 - DMI EDITOR (BOOTABLE USB)
  • csflp
    • Dec 2024
    • 4
    • 中国
    朋友谢谢我的笔
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1253
      • France
      Originally posted by csflp
      朋友谢谢我的笔
      with translate
      Friend, thank you for my pen​
      • csflp
        • Dec 2024
        • 4
        • 中国
        打错字了 Typo​
        • itherogermany
          • Jan 2025
          Hey Maxpower, thanks for your awesome support. I tried the format tool but now the following error occurs. Thanks you so much for your help.
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1253
            • France
            yes normal, now put the contents of my U1 in the key
            the key must be formatted, just add the files​
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1253
              • France
              #26
              for those who struggle to make the key or have access problems
              • rokiii_777
                • Jan 2025
                • 3
                • latvia
                #27
                It says not supported what to do now i have lenovo loq
                  • 21457
                  The DMI can be copied from your bios backup,if you have one, to the new bios using a hex editor, or by running the bios update you will be offered the option to update the serial number etc.
                  • rokiii_777
                    • Jan 2025
                    • 3
                    • latvia
                    #29
                    Originally posted by SMDFlea
                    The DMI can be copied using a hex editor, or by running the bios update you will be offered the option to update the serial number etc.
                    I made a bootable usb and run it on boot and later on screen it showed no supported and some option to call it was like that idk how to do else ..
                    if you dont mind can you explain the process please will be very thankfull...
                      • 21457
                      Type and post the full PC model number and serial. Do you have an SPI programmer, a bios backup ?
                      • rokiii_777
                        • Jan 2025
                        • 3
                        • latvia
                        #31
                        no i dont have and
                        LOQ 15IRX9
                        serial MP2N2WVH
                        • tanchik
                          • Jan 2025
                          • Ukraine
                          #32
                          Thank you very much! You are great!
                          Please pin this files to the first post. Because version 3.5.40 from the first post can't work with last BIOS version and I received error “SMI not ready” or something else.
                          • edwin3562003
                            • Jan 2025
                            • Philippines
                            #33
                            I don't normally create an account to a website just to download a file. But this time I did and fortunately all worth it. I managed to set my serial number and product ID. No more error on bios upon boot up. I wasted 1 day before I came to this solution. Thank you so much hypermk735​!
                            • payam
                              • Nov 2015
                              • 79
                              • iran
                              #34
                              thanks for all help
                              • Multimedia112
                                • Mar 2025
                                Thank you, my friend! this utility helped to update the serial number on lenovo Yoga X1 Gen 7
                                I would have had big problems without your help. A thousand thanks for that
                                • Andromedus_81
                                  • Aug 2023
                                  • 48
                                  • United Kingdom
                                  #36
                                  has anyone had such an error?
                                  • uvaiz
                                    • Jan 2014
                                    • 113
                                    • saudi arabia
                                    #37
                                    setup file available?? 3.5.74
                                    • Andromedus_81
                                      • Aug 2023
                                      • 48
                                      • United Kingdom
                                      #38
                                      uvaiz thank you all is working now.
                                      • abhijitswain@2025
                                        • Jan 2025
                                        • india
                                        #39
                                        no format erro and extra tools verifications failed pls help
                                        • ibo
                                          • Oct 2019
                                          • 94
                                          • Turkiye
                                          #40
                                          Is it possible to install this on a ssd instead of a usb stick?
                                          I cant boot with usb
                                          • coasterghost
                                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                            by coasterghost
                                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                            System Hardware:
                                            Processor: AMD Ryzen 7 PRO 5850U
                                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                            09-08-2025, 10:46 PM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                            Lenovo 3000 Series Schematic
                                            Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                            3000 C100 laptop with Braille keyboard
                                            Lenovo 3000 C
                                            C100, C200 - 15-inch XGA screen
                                            Lenovo 3000 N
                                            N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                            N500 - 15.4 inch screen.
                                            Lenovo 3000 V
                                            V100, V200 - 12.1-inch WXGA models
                                            Lenovo 3000 G
                                            G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                            10-04-2024, 06:05 AM
                                            Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                            09-06-2024, 06:40 AM
                                            This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                            09-06-2024, 06:06 AM
