toshiba satallite c655-s5128 bios
  • asliyucegsm
    • Jun 2011
    • 340
    • Turkiye
    my friend
    mainboard.6050A2355202-MB-A03-TI
    bios+ec flash dump
    thanks
  • hyditech
    • Jun 2012
    • 272
    • nigeria
    Re: toshiba satallite c655-s5128 bios
    Anyone have this bios dump please
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      Send old bios.
      • hyditech
        • Jun 2012
        • 272
        • nigeria
        here is it system does not power up no indication of power led
        thanks man as you help
        • imranromi
          • Jan 2015
          • 1288
          • Pakistan
          Try this and reply.
          • hyditech
            • Jun 2012
            • 272
            • nigeria
            Not working same problem
            • hyditech
              • Jun 2012
              • 272
              • nigeria
              Thanks for helping
              • imranromi
                • Jan 2015
                • 1288
                • Pakistan
                Not bios problem.
                • Esse
                  • Apr 2014
                  • 317
                  • TOGO
                  try this
                  • didouche1200
                    • Oct 2016
                    • 354
                    • 82679911441
                    thanks imranromi its works
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • DProf.
                      TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
                      by DProf.
                      High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
                      Toshiba Dynabook T55/AB, PT55ABP-BJA2
                      MODEL NAME. Satellite L50-D series
                      P[ART NO PS57MN-00600R
                      Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
                      09-26-2024, 04:30 AM
                    • Ziome3eknh
                      Please bios dump toshiba dynabook satellite pro c5-e-104
                      by Ziome3eknh
                      Hello, I need to fix the BIOS dump or some other working one
                      Model: Toshiba Dynabook Satellite pro C5-E-104
                      SN: 70014063A
                      Motherboard: IP3_KN16R_MB_V20_200326A
                      Platform intel Core i5 8gen
                      Attached dump​...
                      04-24-2025, 11:35 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • grimacelord
                      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                      by grimacelord
                      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                      Motherboard model number: DA0PAMB46A1 REV: A
                      Secondary motherboard model number: 0PAB
                      SKU: 685K4UA
                      Serial number is: 5CD3223BJP
                      Recently reflashed this laptop with latest BIOS and once...
                      05-07-2024, 08:06 AM
