Bios on HP Probook 470 G5
  • betalibrae
    • Mar 2024
    • Italy
    Hello guys, I have a tough problem to solve. I'm trying to update the BIOS on my computer, but I've completely forgotten the password I set. Is there a working software method for this model, or is hardware the only possible way?
    Thank you in advance for any help you can give me!
    • 21667
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    https://www.badcaps.net/forum/troubl...ore-posting​
    • Nebukadnerzar_V
      • Oct 2017
      • 23
      • Deutschland
      Hi!
      I have a Probook 470 G5, which does not POST.
      It powers on, screen stays blank, fan slowly ramps up to high speed.
      Tested different RAM, did a CMOS reset, no change.
      Suspecting corrupted BIOS.
      Could somebody please to fix my BIOS?
      HP ProBook 470 G5
      ProdID: 4QW92EA#ABD
      S/N: 5CD8525DF7
      Attached is my dump.
      Thanks in advance!
      • Stefan Steff
        • Mar 2024
        • 344
        Originally posted by Nebukadnerzar_V
        Hi!
        HP ProBook 470 G5
        ProdID: 4QW92EA#ABD
        S/N: 5CD8525DF7
        Thanks in advance!
        Mein Freund your BIOS it's a mess,
        Try this rebuiled BIOS
        • Nebukadnerzar_V
          • Oct 2017
          • 23
          • Deutschland
          Scheiße!
          Well, in that case: Thank you very much for taking the time to fix my BIOS.
          It works!
          And I did not even had to re-enter any of the DMI data - everything just works.
          Great stuff - thanks again and have a good evening!
          • Stefan Steff
            • Mar 2024
            • 344
            Scheiße!
            It works!
            Great, you're welcome.
            P.S. I transferred your DMI data from the damaged dump.
            • studdy05
              Bricked HP Probook 450 G7 Bios questions
              by studdy05
              Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
              Ive got...
              07-08-2025, 09:24 PM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • akwky
              by akwky
              Hi!
              04-14-2025, 01:56 PM
            • al3m0di
              Update bios EFCN58WW to EFCN59WW
              by al3m0di
              Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
              I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
              The BIOS version is EFCN58WW.
              When I turn on the device, it displays the message:
              "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
              The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
              I've tried
              07-29-2024, 10:32 AM
            • 0xx
              2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
              by 0xx
              Hi folks,
              My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
              What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
              I assumed that Windows Update was interrupted due to closing...
              09-14-2025, 03:46 PM
