password for hp elitebook 735 G6
  • JAFATAGNA
    • Apr 2016
    • 59
    • MARRAKECH
    please remove password for hp elitebook 735 G6
    Produit: 5VA22AV
    Serie: 5CG9415JCN
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Produit: 5VA22AV
    Serie: 5CG9415JCN
    CCCC
    • arber97
      • Nov 2018
      • 6
      • tirane
      Hi everyone i need clear bios for Hp Elitebook 735 G6 .I have some laptop Hp Elitebook 735 g6 with bios Password i try Rc Unlocker but not result .Pls help me tu unlock bios thanks
      sn:5CG012PL5
      MB HSN-130C
      I upload my backup bios, bios with Administrator password
      • alfredposadas09
        • Aug 2020
        • 342
        • Philippines
        sn:5CG012PL5
        MB HSN-130C
        here is your unlocked file
        • facefooter
          • Nov 2024
          • 5
          Greetings and thanks for all your work supporting this community.
          I'm trying to remove the bios password for my HP Elitebook 735 G6. I have read the guides and searched the forums but have not been able to solve my issue.
          I removed the bios chip (WINBOND W25Q16JVSIQ) and read it via a XGecu T48, returning successful results. I saved the bin file but when I drag and drop it to the RCUnlocker.exe file, I get the error, "Missing Unlockable Content!"
          Here is my machine info:
          Model number: HP Elitebook 735 G6
          Serial number: 5CG9495TRD
          Motherboard model number/revision: I do not find these despite following the guide
          BIOS dump is attached
          Thank you for any help you can provide.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12441
            WINBOND W25Q16JVSIQ is not a bios chip.
            • facefooter
              • Nov 2024
              • 5
              Well, that would certainly explain my trouble. But I'm confused because I do see text in the dump which appears to be from a bios menu.
              Could it be that the chip is simply W25Q16JV?
              • hoaca388
                Badcaps
                • Jan 2022
                • 12441
                You look for chips with numbers 64, 128, 256... on the face. Ex : W25Q256JV
                • facefooter
                  • Nov 2024
                  • 5
                  Thanks again for your quick help. After a lot more digging I am fairly sure that the 25Q16JV chip is, in fact, the bios chip. There are no other bios candidates on the motherboard and the data sheet from Winbond seems to indicate it's a bios chip. I even found the bios listed in the dump.
                  Any other thoughts on why I'm getting the "Missing Unlockable Content!" error?
                  Thanks!
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12441
                    Thanks!
                    I bowed my head.
                    • facefooter
                      • Nov 2024
                      • 5
                      I'm unsure what your response means but I will assume you're saying that I'm wrong.
                      Thanks again for your assistance.
                        • 22293
                        The file you posted ( W25Q16JV​ 2MB) is not the contents of the bios chip, it is a firmware chip for Realtek Wifi DASH ,remote management https://www.realtek.com/Article/News...2326&app_id=18
                        Click image for larger version  Name:	Capture.jpg Views:	0 Size:	85.9 KB ID:	3516212
                        • facefooter
                          • Nov 2024
                          • 5
                          Originally posted by SMDFlea
                          The file you posted ( W25Q16JV​ 2MB) is not the contents of the bios chip, it is a firmware chip for Realtek Wifi DASH ,remote management[/ATTACH]
                          Many thanks, that makes sense. I was finally able to track down a board diagram and learned that there are actually two bios chips on the HP Elitebook 735 G6 - one on the bottom labeled U365 and one on the top, U366. I believe they're both W25Q128JV chips which are smaller and surface mounted with no legs.
                          Do you know if it's possible to reprogram both chips using RCUnlocker? HP Elitebook is listed as a compatible laptop but perhaps not this model number?
                            • 22293
                            Posts moved to 735 G6 thread topic. The password can be removed if you post the bios backup.
                            • mohaadben
                              • Oct 2016
                              • 27
                              • algeria
                              HI
                              Request help unlocking
                              hp elitebook 735 g6
                              SN 5CG01567ST
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12441
                                Originally posted by mohaadben
                                HI
                                hp elitebook 735 g6
                                SN 5CG01567ST
                                Unlocked
                                • mohaadben
                                  • Oct 2016
                                  • 27
                                  • algeria
                                  Unlocked
                                  It still asks for password
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12441
                                    Post main bios file.
                                    • mohaadben
                                      • Oct 2016
                                      • 27
                                      • algeria
                                      The original BIOS file I uploaded earlier is located above
                                      I used rcunlocker and it didn't work
                                      • mohaadben
                                        • Oct 2016
                                        • 27
                                        • algeria
                                        Solved
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          >Read BIOS guides, methods, resources and tools
                                          Ack
                                          >Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Ack
                                          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                          01-30-2025, 04:26 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • Wutru
                                          HP Elitebook 820 G4 BIOS repair assistance required
                                          by Wutru
                                          Hi guys,
                                          If someone would be able to provide some expertise, I'd be very grateful.
                                          BIOS Corruption - Cause
                                          So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                          After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                          09-06-2025, 10:32 AM
