HP 840 g10 bios
post the original contents of the bios chip..not the update on the website..
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
you need an SPI programmerComment
HP EliteBook 840 g10
motherboard DAOX8TMB8E0 REV. E
SN 5CD4042H9R
please disable absolute persistanceAttached Filesif you find these attachements useful please consider making a small donation to the site
please help me fix the bios not displaying
HP ELITEBOOK 840 G10
sn 2MQ420051SAttached Filesif you find these attachements useful please consider making a small donation to the site
try this one.Attached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by evilgenius31Hi All,
I was told to post my corrupted bios dump here. My Zephyrus G14 GA401QH-211 is missing the serial number in the bios. NVME drives can't be detected by the bios either. The bios version is 410.
Serial: M4NRKD01530915H
Thanks in advance!...-
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
- Loading...
