Razer RZ09-0369AE22 - da560_mb mp v4.0
  • sikocan
    • Oct 2019
    • 344
    Hi team,
    Could someone provide a BIOS for this motherboard da560_mb mp v4.0
    Original fault is it will not turn on. All main power rails present when battery is in, except RAM, CPU & GPU and Integrated GPU, just can't get it to turn on. It charges battery fine, I can't see any data pin activity on the BIOS pins, however it does get power on BIOS pins. Thank you. Attached is the 128mb chip. Serial of laptop is BY2120M18700368
  • volinakis
    • Jan 2021
    • 2748
    • N/A
    Originally posted by sikocan
    Hi team,
    try this clean and updated ME file.
    • sikocan
      • Oct 2019
      • 344
      Thank you, I'll try it out tomorrow, this will help at least rule out the BIOS.
      For those interested, you can see the unreleased videos here:
      Part 1 https://youtu.be/pwZjTc39MiQ
      Part 2 https://youtu.be/7n7lREqzjds
      Crazy laptop, tough one. On another forum on this site, the user had given up on similar issue. Let's see how it goes.
      • sikocan
        • Oct 2019
        • 344
        It is still the same fault, I'll leave it as potentially a CPU or GPU fault. Thank you again
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • vinaypundith
          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
          by vinaypundith
          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
          So, I'm looking for a BIOS dump for this machine - a 16MB one....
          08-03-2024, 12:32 PM
        • Vesko356
          by Vesko356
          08-11-2023, 03:27 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
