Laptop not booting after reading/fashing bios chip
    Hello
    I had a laptop working (booting ok) but it was bios password lock.
    I have dumped a bios chip GD25LB64C, modified the bin and injected back. (I have made the mistake to not unselect "OTP secu R" on read & flash).
    Computer power led was lighting up but no screen at all (no logo or else), then computer led stop a few min later.
    I tried to flash back the original unmodified dump, but same problem.... Computer doesn"t start.
    Now i have an error on verify process (I try different thing (even erase the chip before)
    Pins Detected Passed!
    ID ......OK!
    Erase ...Succeeded. Time : 9.265 S
    Data Protect Disable...OK!
    Programming FLASH ...Succeeded. Time : 29468ms
    Verifying FLASH ...Succeeded. Time : 3968ms
    Programming STATUS REG ...Succeeded. Time : 0ms
    Verifying STATUS REG ...
    STATUS REG ERROR at: 0001 Buffer Value :0x02 --- IC Value : 0x3A
    Verifying Succeeded. Time : 265ms
    Programming ...Failed
    Any ideas? thanks
    Originally posted by Buzzfuzz2k View Post
    Hello
    Any ideas? thanks
    You MUST:
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    Become a Badcaps supporter
    Thanks to all supporters.​
      Hi
      thanks for the information, i know it, i didn't provide it because i though it was not relevant as it's just a problem of reading/writting a chip.
      I didn't want to give useless informations as i have the program i want to send, but i don't understand where i did a mistake that prevent from booting?
      Brand: unowhy
      Serial: IFP129034378
      Model Y13G011S5EI
        I have managed to remove the error by "unclicking" default activate " Programming Status register."
        But laptop is still not booting even with the original file...
        I have another laptop (the same) that boot, maybe i can take another dump to send to the non working one? but what option to select to be sure to get things right?
        thanks
