Laptop not booting after reading/fashing bios chip
  • Buzzfuzz2k
    • Nov 2023
    • 29
    • france
    Hello
    I had a laptop working (booting ok) but it was bios password lock.
    I have dumped a bios chip GD25LB64C, modified the bin and injected back. (I have made the mistake to not unselect "OTP secu R" on read & flash).
    Computer power led was lighting up but no screen at all (no logo or else), then computer led stop a few min later.
    I tried to flash back the original unmodified dump, but same problem.... Computer doesn"t start.
    Now i have an error on verify process (I try different thing (even erase the chip before)
    Pins Detected Passed!
    ID ......OK!
    Erase ...Succeeded. Time : 9.265 S
    Data Protect Disable...OK!
    Programming FLASH ...Succeeded. Time : 29468ms
    Verifying FLASH ...Succeeded. Time : 3968ms
    Programming STATUS REG ...Succeeded. Time : 0ms
    Verifying STATUS REG ...
    STATUS REG ERROR at: 0001 Buffer Value :0x02 --- IC Value : 0x3A
    Verifying Succeeded. Time : 265ms
    Programming ...Failed
    Any ideas? thanks
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    • Gadget & motorcycle addicted
    Originally posted by Buzzfuzz2k
    Hello
    Any ideas? thanks
    You MUST:
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    Become a Badcaps supporter
    Thanks to all supporters.
    • Buzzfuzz2k
      • Nov 2023
      • 29
      • france
      Hi
      thanks for the information, i know it, i didn't provide it because i though it was not relevant as it's just a problem of reading/writting a chip.
      I didn't want to give useless informations as i have the program i want to send, but i don't understand where i did a mistake that prevent from booting?
      Brand: unowhy
      Serial: IFP129034378
      Model Y13G011S5EI
      • Buzzfuzz2k
        • Nov 2023
        • 29
        • france
        I have managed to remove the error by "unclicking" default activate " Programming Status register."
        But laptop is still not booting even with the original file...
        I have another laptop (the same) that boot, maybe i can take another dump to send to the non working one? but what option to select to be sure to get things right?
        thanks
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
        • Berun
          HP EliteDesk 800 G6 mini - BIOS Chip (GD25B127DSIG) replacement after epic fail :D
          by Berun
          Hello All,
          I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
          I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
          I read the Chip on board 8 times (with power...
          04-09-2026, 06:24 AM
        • thxd43
          Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
          by thxd43
          Hello, first of all, excuse me, I am using the translator, English is not my native language.
          I have a Lenovo ideapad 330S - 14IKB laptop.
          The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
          02-23-2023, 08:37 PM
        • hotcrossedbuns999
          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
          by hotcrossedbuns999
          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
          3. I could only locate two chips that look like bios chips. Could someone verify this
          01-03-2025, 12:32 PM
