Lenovo T460s Me Clean?
This topic is closed.
  • duder
    • Oct 2013
    • 41
    • canada
    Would someone please be able to look at this BIOS? The machine works fine but takes 15 seconds to POST and the MEI Version is blank. Intel ME will not install. I had used lenovo auto-patcher to remove supervisor password. That worked and I have since updated the BIOS to the latest version. Thanks in advance.
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    Find an existing thread using the search engine, and post your request there. Make sure to add all required information in your post as per the rules.
    Thread closed.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
    • grimacelord
      by grimacelord
      Hello there.
      History:
      03-15-2023, 03:29 PM
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • mkdj
      Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
      by mkdj
      Dear all,
      I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
      Here the steps I have taken to fix the laptop:
      - downloaded latest BIOS from Lenovo Website...
      10-18-2025, 03:43 AM
    • jendkkd jeje
      Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
      by jendkkd jeje
      So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
      I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
      10-11-2024, 03:12 PM
