Hello. Customer tried to update BIOS via Lenovo software. Update has been failed and unit was dead completely. I found working BIOS dump and flashed it. Now unit turns on very slowly, and, after every booting it tries to recover ME firmware and fails everytime. Also, unit can't detect nvme disk, so i can't boot windows to flash ME with Lenovo software. Can someone provide to me 100% working dump? There're 2 flash IC's: U49 and U801. I flashed only U49. Thanks in advance.
Lenovo Carbon X1 9th Gen bios
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
Failed reading the ME firmware.
2100etection error on storage device (M.2)
Lenovo ThinkPad X1 Carbon 9th Gen
SN:MJ-0G6Y3G
Type:20XW-00FSUS
This is the original extracted BIOS. I think i need the ME Region Cleaned.
Thank You
Attached FilesComment
Lenovo ThinkPad X1 Carbon 9th-Gen
model 20xxs3la1m
s/n : PF3VJTBQ
nm-d341 rev 1,0
Please help me fix the bios. There is no imageAttached FilesComment
Last edited by SMDFlea; 07-02-2024, 03:49 AM. Reason: X1 Carbon 9th Generation Laptop (ThinkPad) - Type 20XX
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
LENOVO THINKPAD X1 Carbon 9th Gen
(Type 20XW)
ST : PF-307LWE
The firmware is damaged, please help to repair it. Thank you!
(Type 20XW)
ST : PF-2TA4EX
Slow startup, needs cleaning.Thanks.Comment
Hi there, firstly, this site is amazing and so glad I found it, I was lucky enough to recover some devices from a friends old garage clear out, one of them was a X1 Carbon 9th Gen, it was working great until I connected it to the internet and then it froze, it has computrace/absolute protection on it and i do not know the bios password either, if you could let me know how I can get this sorted that would be greatly appreciated! Details are as follows:
Serial Number: PF-3NGLSN
Type Number: 20XW-CT01WW
Assuming you have the correct file to flash the bios, can you recommend what gadget I need to get that done? Im in the UK and have found this on amazon:
https://www.amazon.co.uk/KeeYees-SOI...1&sr=8-1-fkmr0
let me know if thats a good tool, thanks in advance!!Comment
Any tool will do it. Cheap CH programmer or raspberry pi. I recommend the bios clip mainly to not have to desolder.
Imo, this thread is very helpful to me. I hardware read the bios and it looks like this guy's:Instead I'm used to dump looking like this:
So now I look for versions like the latter and it's 1.68(N32ET92W) maybe if I downgrade to that version my rom becomes normal and not weird like this:
Not super hopeful though because his post is on 1/19/2024 and that date already AFTER this bios is released.
Hi FeerBaron, unfortunately I am new to this and dont quite follow your suggestion, I have the following programmer - KeeYees SOP8 SOIC8 Test Clip for EEPROM 25CXX / 24CXX + CH341A 24 25 Series EEPROM Flash BIOS USB Programmer
I am using RT809F Serial ISP Programmer software version 20190508 and cannot find my programmer listed in the supported devices, do you know how to get that working or what other software I should be using?
please remove bios password
i tried with lenovo patcher but nothing happened
SR: 1S20XXS3LB1HPF3NLXPJ
thinkpad carbon x1 9th gen
thanks in advanceAttached FilesComment
Hello! Please help me fix the BIOS. The laptop does not boot, black screen.
X1 carbon gen 9
20XX-S00PS00
PF-2ZJB6QAttached FilesComment
by MaxonDomkratHi everyone.
I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...-
Channel: BIOS Requests ONLY!
by Gangubasuslenovo thinkpad x1 carbon gen 12
Model 21KC-FVT001
S/N PF-4CQ9FG
CPU genuine intel(r) cpu 0000
BIOS N3YET06C (0.06)
Hello! I need help getting a modified BIOS for my system. Since I have an engineering processor, is it possible to add the microcode of this engineering processor to the latest BIOS for this laptop model? I think since the BIOS is old, that's why the Wi-Fi driver is not installed on Win10 and Win11, the sound is not adjusted (error code 10 in the device manager) and the screen brightness. The laptop also has BIOS chips W25Q512NW and W25Q128JV, how can...-
by ericoFirst of all, ive veen reading these forums for some time and its always veen very helpful, so i thank you all for this amazing comunity.
I have a lmq-2 13268-1 motherboard from a lenovo x1 carbon 3rd gen. And the MX25l12873f (U49) bios pin 8 is not getting voltage.
So far these are my diagnostics:
When given 19v trough power adapter, consumption reads 0.003 amps for about 5 seconds then nothing.
When power button pressed same result, and i get three green blinking lights from the pwr btn led. But foesnt turn on.
If i plug the battery... -
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by 1g0rHello everyone,
First, the data in brief:
Manufacturer: Lenovo
Model: ThinkPad L15 G3 21C3-0016GE
motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
IC Bios 1: MX77L25650F
IC Bios 2: MX25L25673G
EC Chip: NPCX997KAABX
So far I've been a silent reader, but now I need your help
I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge - Loading...
