Lenovo X1 Carbon BIOS not getting voltage
  • erico
    • Jun 2022
    • Spain
    First of all, ive veen reading these forums for some time and its always veen very helpful, so i thank you all for this amazing comunity.
    I have a lmq-2 13268-1 motherboard from a lenovo x1 carbon 3rd gen. And the MX25l12873f (U49) bios pin 8 is not getting voltage.
    So far these are my diagnostics:
    When given 19v trough power adapter, consumption reads 0.003 amps for about 5 seconds then nothing.
    When power button pressed same result, and i get three green blinking lights from the pwr btn led. But foesnt turn on.
    If i plug the battery i get the same behaviour but the consumptions gets constant at about 0.003 amps. No battery charging.
    No shorts found whatsoever. Nothing gets hot. I get 5v and 3.3v rails on the coils when i press pwr btn. Then nothing.
    Never getting voltage on cpu coils. And the resistance to ground from those seems normal. Between 10 and 20 ohms.
    BIOS never gets the 3v voltage. In this board, schematics indicates this 3v bios rail is named vcc3lan and it seems coming from the think engine super io chip (U101) and passsin trought the main CPU. But i never find it droping those 3v anywhere.
    Ive trying reprogramming bios with ch341 programmer and it seems fine, tested with difetent bios files always same result, even with bios desoldered the behaviour its always the same.
    Everything indicates that think engine is not working properly.
    Also i would like to ask what is the mec 1633 chip for? And if it is somewhats related to the 3v bios rail.
    Any help would be apreciated!
  • erico
    • Jun 2022
    • Spain
    Ive just realized this is not the right sub for this post. Any admin could please move it to the right laptop sub please. Thanks!
      SMDFlea commented
      Editing a comment
      Thread moved.
    • 22157
    LINK to schematic https://www.badcaps.net/forum/troubl...hematic-needed
    • MaxonDomkrat
      Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
      by MaxonDomkrat
      Hi everyone.
      I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
      07-30-2025, 01:27 PM
    • lucaszmn
      by lucaszmn
      Problem:
      Initial Findings:
      • I concluded that the
      08-12-2025, 03:01 PM
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
    • grimacelord
      by grimacelord
      Hello there.
      History:
      03-15-2023, 03:29 PM
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
