Clevo n240lu bios too big
  • eukal
    • Jul 2012
    • 43
    • belgique
    Hello i have an Clevo N240lu from a friend that doesn't start anymore. It power on but not display black screen and after few seconds fan spin at full speed.
    I have try to replace ram on both slots but nothing so i think the bios is possibly corrupted.
    I have backup the bios and download a new one on the clevo website but the size is too big.
    Could you help me to have the good size bios ?
    Thanks.
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria šŸ‡§šŸ‡¬
    Thanks.
    Your bios backup is 1MB should be 8MB, so either you've dumped the wrong chip, or the chip is not read properly. Try again. Post SPI chip markings.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • eukal
      • Jul 2012
      • 43
      • belgique
      Hello, My bad, wrong ch341a software . Here is a good backup and i have succes to flash the clevo website bios.
      Now the laptop stay on but always with fan at full speed and no picture. All power supply is up and running. Bios pin have 1.8v except pin 4 abd 7 so i thin no bios problem am i right ?
      I doesn't find any other n240lu bios file, only the file of clevo website, just other on vinafix but i'm not no registered.
      And no shortcut on the board.
      In the zip file from clevo there are an ec file, i think i doesn't need them but maybee i'm wrong ? Peraphs with bios update i have to update this ec file ? If yes is this possible with ch341a ?
      Thanks for any help.
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria šŸ‡§šŸ‡¬
        I doesn't find any other n240lu bios file, only the file of clevo website...
        BIOS guides, methods, resources and tools
        6.2.1. Clevo
        No bios downloads at official support page.
        See: https://www.badcaps.net/forum/showpo...89&postcount=2
        log in with - username repo . password repo
        • eukal
          • Jul 2012
          • 43
          • belgique
          Thanks for this very quick answer i will try these bios from the older to newer and check if one is working and come back to tell the result.
          • eukal
            • Jul 2012
            • 43
            • belgique
            Hello i have try all bios from the repo but no luck always the laptop start, black screen and the fan speed up quickly and turn at full speed. Peraphs the ec chip but i have not the progammer to try flashing it. I have verify the board but found nothing suspect.
            If you have another idea thanks in advance.
            • m1ch43lzm
              Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
              by m1ch43lzm
              Hi everyone
              I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
              Programmer models: XGecu TL866II Plus / T48 / T56 / T76
              Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
              There's also an extra OTP Secu.R...
              09-06-2025, 05:47 PM
            • to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
              by to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
              I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
              This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
              I have opened the laptop and identified the main BIOS chip...
              10-24-2025, 01:35 AM
            • Chris_stand
              Clevo PD50PNN won't boot after BIOS Backup
              by Chris_stand
              i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
              At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
              Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
              But the...
              04-28-2023, 03:08 PM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • princebuzz
              BIOS REQUEST FOR CLEVO PE60RNE-G
              by princebuzz
              I’m looking for the correct BIOS / EC / ME firmware for a CLEVO PE60RNEQ laptop that was sold by Scan as a 3XS system. The laptop has developed a boot issue that appears to be firmware-related, and I’m hoping someone can provide a dump or the correct files.
              System Information:
              • Base laptop model: CLEVO PE60RNEQ (NP60RNEQ)
              • Motherboard ID: PE60RNE_RND_RNC
              • Vendor: Scan 3XS (UK)
              • Unfortunately, I no longer have the original box.
              Firmware Versions (from BIOS):
              • BIOS Version: 1.07.07SCI
              • EC/KBC Firmware Version: 1.07.07
              • Intel ME Firmware Version:
              Yesterday, 03:09 PM
