Help with Thinkpad Maintenace Utility on T590
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1224
    • France
    Originally posted by keczuk
    hmmm why u not answer me ? i see you are online everyday
    Click image for larger version  Name:	222.jpg Views:	0 Size:	94.9 KB ID:	3175478
    My version is not finished at the moment
    I don't have time to take care of it and it is not available .
    Write access is locked, if your usb key is well done with the utility provided,
    you must have the rights.
    No access, weird.
    Rest of password, or Ec corrupted may be ?
    try to load the default setup, clean the security tab etc. and try again.
    For block 84, I have no idea what it corresponds to
    I don't know what you originally did to the PC, it's hard to help you anymore
    try this one ThinkPad Maintenance Utilities V1.19(X64)
    https://www.badcaps.net/forum/troubl...57#post1831957
    • x16
      • May 2015
      • 83
      Sorry i didn't see your post.
      But i found solution now!!!
      Problem ist SVOD4. In some cases the svod4 programmer makes the mec chip (some kind of) locked. If this happenes the notebook is running, but mec isn't writable.
      Then you need RT809H, write the dump back with this programmer and the problem ist gone, now i can write all data like B0 etc with U1. No Problems anymore and no error messages.
      The funny part is: once programming with RT809H, programming with svod4 is possible again.
      • keczuk
        • Dec 2019
        • 83
        • WWW
        I don't have time to take care of it and it is not available...
        Yes i have also password in my broken board. So if the password is set i can't use this pen for reset DMI ? if i change some lines i can remove model name and UUID so meybe is some way for edit all dmi
        Last edited by Vesko356; 01-15-2024, 02:02 PM. Reason: Removed full OP qute with image
        • liangshaowei1688
          • Apr 2021
          • zhongguo
          can you post your EC dumps?
          have you tried planar services?
          with dump eeprom (5), are there serials and information marked in it ?
          you can try with SERUPDT (exemple 7 and 8 in my pics)
          Click image for larger version Name:	399779571_217912041320157_5257554185771111853_n.jpg Views:	0 Size:	407.8 KB ID:	3156564
          with lenovo diskette
          create eeprom.dat with serial info
          place in root of usbkey
          IN EFI SHELL
          cd A:\MTMSN\ThinkPad\
          for write
          SERUPDT L eeprom.dat
          for save in eeprom.dat
          SERUPDT S eeprom.dat
          Click image for larger version Name:	386453902_1041202147221888_1671781784116666234_n.jpg Views:	0 Size:	20.4 KB ID:	3156563
          Hello, can you share your software???
          • jawal37
            • Feb 2013
            • 40
            • afric
            we find the different pages in bootx64 written on EC
            This bit in bios with no password if password in bios this bit is moved in block 6-7
            • jawal37
              • Feb 2013
              • 40
              • afric
              #26
              • caphamxa
                • May 2025
                • 3
                • NORWAY
                #27
                I have a Lenovo P53, it was on supervisor password which I removed by using a method here on badcaps ( by shorting a specified circuit) after resetting password I saved and exit bios. My model number serial number was changed which was showing Lenovo L15. I tried to change it back using thinkpad maintenance utility and when I try to select ¨CO¨ and type my serial it shows CO type not correct. Searching internet I found out another option of using command ¨20¨. which I tried with random number and it worked. but I think its not type 20 because serial on the back of laptop doesn't fit syntax of that command. Please help. I am at beginners level in these techniques.
                Details- Type 20QN-003FMX S/N PF-1CY6UJ 20/03 THESE ARE ON BACK
                Which option should I chose and how should I input I tried like this but its not working 1S20QN003FMXPF1CY6UJ
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1224
                  • France
                  #28
                  C0 (zero) not CO
                  • caphamxa
                    • May 2025
                    • 3
                    • NORWAY
                    #29
                    Thanks a lot, it was a silly mistake. Successfully changed and fixed.
                    • caphamxa
                      • May 2025
                      • 3
                      • NORWAY
                      #30
                      where can i get the other serials such as b0 etc, is it necessary to have other data too. I think initializing eprom removed all the information.
                      • Stefan Steff
                        • Mar 2024
                        • 244
                        • Romania
                        #31
                        Usually there must be a sticker for B0 like in attached image...
                        For C0 you can put together like this example:
                        1. Machine Type Model : 20S0002UAD
                        2. Serial Number : PF2BMNC6
                        3. 1S + Machine Type Model + Serial Number
                        4. Final: 1S20S0002UADPF2BMNC6
                          Lenovo ThinkPad T590 Notebook T Specification for Upgrade or Repair
                          This specification for the Lenovo ThinkPad T590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T590 boardview and T590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                          09-06-2024, 03:30 PM
                          09-06-2024, 03:21 PM
