Lenovo v14-iil bios need
  • Zickko10
    • Sep 2021
    • 83
    • Nigeria
    PROBLEM: the laptop keeps restarting itself, not displaying and the power led light is blinking
    the board number :GS44D/S54D NM-C711 REV 1.0
    Model name :82c4
    S/n:82C401EBAK
    and here is the old Bios bin
  • hoaca388
    Badcaps
    • Jan 2022
    • 11713
    type:82c4
    Serial number , this is the new forum rule.
      • 20807
      type:82c4
      You must always post the serial number/service tag/SNID as per the rules
      https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/91593-rules-update-for-bios-requests-offers-avoid-banning-read-before-posting?t=103570
      • Zickko10
        • Sep 2021
        • 83
        • Nigeria
        Noted
        I have done that now
        • hoaca388
          Badcaps
          • Jan 2022
          • 11713
          Model name :82c4
          S/n:82C401EBAK
          V14-IIL Laptop (Lenovo) - Type 82C4
          • Zickko10
            • Sep 2021
            • 83
            • Nigeria
            I have flash this bin
            still the same problem
            Nothing change
            • hoaca388
              Badcaps
              • Jan 2022
              • 11713
              Nothing change
              You not have bios issue.
              • Zickko10
                • Sep 2021
                • 83
                • Nigeria
                Okay
                pls who can guide me on how to solve this issue?
                • monicaco92
                  • Nov 2020
                  • 6
                  • spain
                  Hi!
                  Hello, I have done the DMI process on the original BIOS but I still can't get it to give video. All the voltages and measurements are correct in the hardware, it even gives video via HDMI. The BIOS has problems. I am attaching the BIOS that originally came with the computer.
                  Equipment data:
                  Lenovo V14-IIL
                  Model Name: 82C4
                  S/N:PF2RTVJC
                  MTM: 82C400U2SP
                  MFG Date": 2021/07/29
                  Factory ID: YH
                  MO: PF9XB1729075
                  Please, if you can do something, I'll appreciate it. Thanks in advance.
                  Reggards.
                    SMDFlea commented
                    Editing a comment
                    Post merged with V14-IIL thread.
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  Originally posted by monicaco92
                  Hi!
                  Equipment data:
                  Lenovo V14-IIL
                  Model Name: 82C4
                  S/N:PF2RTVJC
                  MTM: 82C400U2SP
                  Factory ID: YH
                  MO: PF9XB1729075
                  Reggards.
                  fresh bin from website added dmi give feedback
                    • 20807
                    Hi!
                    This problem is happening on a few different lenovo models,and its caused by a bios update. Downgrading the bios to an older version should fix it.
                    • monicaco92
                      • Nov 2020
                      • 6
                      • spain
                      ok, try flashing a previous bios version. thanks for the help!
                      Reggards.
                        • 20807
                        Reggards.
                        I moved your post from the S145 thread as it was off-topic. A reply to your post in the S145 was made at the same time as i moved your post to this thread. I`ve merged that reply with this thread now https://www.badcaps.net/forum/troubl...85#post3460585 , if the downgrade doesn`t work try that bios
                        • monicaco92
                          • Nov 2020
                          • 6
                          • spain
                          I have lowered the version and it still does not give video only through HDMI output, I have tried with the bios that you sent me and it still has the same problem, I have measured the entire video part from the connector all the way to the GPU part and everything is perfect, the fan works normally, the kbc has all its measurements correct.
                            SMDFlea commented
                            Editing a comment
                            Its not a problem with the bios then so must be hardware.
                        • monicaco92
                          • Nov 2020
                          • 6
                          • spain
                          Can you send me a BIOS file that contains an older version? I would like to do some tests before reballing the CPU/GPU chip.
                          thank !
                          • Stefan Steff
                            • Mar 2024
                            • 246
                            • Romania
                            Check the fuses around the LCD connector (on the main board both sides).. There is a fuse for backlight and others on 3.3V and any of them may be gone.
                            I guess you have an LCD backlight issue...when the laptop starts up light the screen with a flashlight and if you see the Lenovo logo then sure the backlight is your problem
                            • monicaco92
                              • Nov 2020
                              • 6
                              • spain
                              It drives me crazy because all the voltages exist, the fuses are perfect. The video line measurements using an oscilloscope are perfect, those waves are very healthy. I have replaced the BIOS chip with a new one and it still doesn't give video. Do you have any BIOS with an older version?
                              • Stefan Steff
                                • Mar 2024
                                • 246
                                • Romania
                                I see the 14IIL and 15IIL share the same bios...
                                Click image for larger version  Name:	image.png Views:	0 Size:	145.3 KB ID:	3460728
                                I have a CLEAR ME version for 15IIL to try...
                                • monicaco92
                                  • Nov 2020
                                  • 6
                                  • spain
                                  Can you lend it to me? I have no more options with this team.
                                  thank !
                                  • Stefan Steff
                                    • Mar 2024
                                    • 246
                                    • Romania
                                    thank !
                                    It's attached to the earlier post...
                                    Click image for larger version  Name:	image.png Views:	0 Size:	1.9 KB ID:	3460876
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • grimacelord
                                      Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                      by grimacelord
                                      Hello there.
                                      I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                      History:
                                      1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                      I searched for this error online and discovered...
                                      03-15-2023, 03:29 PM
                                    • jendkkd jeje
                                      Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                      by jendkkd jeje
                                      So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                      I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                      10-11-2024, 03:12 PM
                                    • mximiliandz
                                      help bios lenovo ideapad s145-14iil type 81w6
                                      by mximiliandz
                                      Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                      06-20-2025, 06:50 AM
                                    • 1g0r
                                      Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                      by 1g0r
                                      First, the data in brief:
                                      Manufacturer: Lenovo
                                      Model: ThinkPad L15 G3 21C3-0016GE
                                      motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                      IC Bios 1: MX77L25650F
                                      IC Bios 2​: MX25L25673G
                                      EC Chip: NPCX997KAABX
                                      So far I've been a silent reader, but now I need your help
                                      I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                      I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                      The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                      01-18-2025, 02:39 AM
