Bios Programmer help
  • salmanlxm
    • Feb 2013
    • 33
    • bangladesh
    I want to buy a bios programmer
    which can work laptop and desktop mother board .
    please give suggestions .
    which programmer i can buy .
  • asliyucegsm
    • Jun 2011
    • 350
    • Turkiye
    Re: Bios Programmer help
    my friend
    see here
    http://www.xeltek.com/SuperPro-3000u-Programmer/
    • dj_ricoh
      • 2073
      • uk
      Originally posted by salmanlxm
      i got this
      http://www.ebay.co.uk/itm/EZP2010-Hi...item4acc4ec9df
      last week i used to program skybox`s
      • lefos
        • Nov 2013
        • 321
        • Greece
        @djricoh with that one can you flash bios on laptops? I ve seen it but I think it needs some kind of adaptor!
        • dj_ricoh
          • 2073
          • uk
          yes!
          but you get a standard soic-8 pin adapter actually 2 adapters.
          "What do you get?
          15. Simple socket for SMD chips x 2"
          and i bought a clip so i won`t have to solder and desolder twice.
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            What do you mean by 'clip'?
            ...the quieter you become the more you are able to hear...
            • dj_ricoh
              • 2073
              • uk
              like this one
              http://www.lynx-india.com/published/...%20HDD_enl.jpg
              but i found out that you need to unsolder the chip
              first time i try it power the mobo from my usb and the usb got stuck.
              so unsolder read/write and put it back
              • heavyice
                • Nov 2013
                • 19
                • India
                I purchased this few days back and seems to be working very well with latest and old laptops and desktops. Comes with 9 adapters and supports over 13000 chips. I purchased it as I heard a lot of good things about it.
                http://www.ebay.in/itm/320967107440?...84.m1439.l2649
                • STKR123
                  The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                  by STKR123
                  Greetings badcaps community,
                  I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                  So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                  Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                  I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                  These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                  I learned that desoldering...
                  10-29-2024, 06:03 AM
                • hotcrossedbuns999
                  M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                  by hotcrossedbuns999
                  My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                  1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                  2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                  3. I could only locate two chips that look like bios chips. Could someone verify this
                  01-03-2025, 12:32 PM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • zlr8r
                  looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                  by zlr8r
                  looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                  cheers
                  Dell Inspiron 17 (7786) Laptop
                  Service Tag: 5J0NHT2
                  Bios: 1.9.0
                  MOBO: RO 15 17 WHL 2GB MB / 18706-2
                  Attached;
                  1. My saved bios using a programmer
                  2. Dells Bios updater .exe (v1.16)
                  3. Dells Bios recovery file
                  4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                  5. Image of ME...
                  12-18-2023, 03:08 PM
                  by Vesko356
                  08-11-2023, 03:27 AM
