Lenovo t510i bad bios flash
  • scobie_21
    • Jul 2011
    • 144
    Hi would anybody know where I would get a bios dump from this model t510i 4314 also I need the schematic for this same board 08272-3. i have tried flashing the chip with the files from Lenovo website without much success.
    Thanks in Advance
  • Francisco.s
    • 686
    • Spain
    Re: Lenovo t510i bad bios flash
    Thanks in Advance
    Have you flashing it with an external programmer?
    If not, try it this way.
    • scobie_21
      • Jul 2011
      • 144
      Yeah thats what I am doing I dont rely on these Crisis way using floppy or usb key. I removed it from the board, the problem is there are 3 files in the Lenovo bios package 1 compressed (1mb ish) and 2 uncompressed usually named xxxxx.FL1, xxxxxxx.fl2 and slightly different number to other 2 also ending in .FL1 both files around 3mb, so I followed the instructions for decompressing the compressed one it then becomes 3mb and I have tried flashing all 3 without success.Camera led flashes, fan spins unit turns on it itself and then off again pauses for a a while then does it again. I know the unit worked as I recently serviced it. But it died during bios update a few months later. The schematic I have (wrong version one) shows 2 spi chips 1 bios other EC controller, problem is I can only find 1 IC the Spi1 chip no sign of the other one. I can only assume then there is no seperate Ec controller on this model and SPI1 is the correct EEprom.
      • dycc
        Vision
        • Nov 2011
        • 625
        • Côte d'Ivoire
        ps08,l08 or 24ps08 is the second chip
        • dycc
          Vision
          • Nov 2011
          • 625
          • Côte d'Ivoire
          • scobie_21
            • Jul 2011
            • 144
            Thanks I will check that out in a while.
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              in your case there is no other way than to find dumps for these two chips. what is the size of your bios (1mb 2mb 4mb or 8mb) ???? because 3mb is not a correct size.
              is yours I3 i5 or i7 lapy ????????
              • scobie_21
                • Jul 2011
                • 144
                Its an i5 and also in the bios package there are 3 files 2 cannot be decompressed so Im assuming they are already decompressed these are 3mb the other 1 is 1mb and when decompressed using the utility (e_bcpvpw) it becomes 3mb. Its an unusual system they use. Yes you are right if I could get a dump of the bios and EC that would certainly do the job.
                Thanks for your input.
                • dycc
                  Vision
                  • Nov 2011
                  • 625
                  • Côte d'Ivoire
                  know someone who get the same lapy. will let you know if i will be allow to unscrew and dump.
                  • scobie_21
                    • Jul 2011
                    • 144
                    That would be great. thanks for your assistance
                    • fredo
                      • Aug 2016
                      • 81
                      • syria
                      T510i bios
                      • alvin24705
                        • Dec 2015
                        • 16
                        • Indonesia
                        Originally posted by fredo
                        T510i bios
                        thnks for advice
                        • excelbaba
                          • Dec 2021
                          • nigeria
                          I have thinkpad t510 with supervising password. Have programmed the bios with 6 diffrent bios files . The password still remain onthe system.any way forward will be highly appreciated
                            • 22011
                            https://www.badcaps.net/forum/showth...10#post1118568
                            • abhorsen
                              Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                              by abhorsen
                              Hey guys,
                              Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                              Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                              Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                              07-06-2023, 10:22 AM
                            • Nicola Bianchi
                              Lenovo x1 nano gen 1 -- bricked -- where to flash the bios/fw
                              by Nicola Bianchi
                              Hello!
                              A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
                              No the machine power up, but it stuck in a recovery state and I can not do much.
                              Lenovo X1 Nano Gen 1
                              Type: 20UN - X021US
                              S/N: R9 - 10W2D9
                              I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦‍♂️
                              So here I am to ask for help.
                              I opened the laptop and I found a chip that may be the target, on it I've:
                              Winbond 25R256...
                              01-11-2025, 09:50 AM
                            • 1g0r
                              Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                              by 1g0r
                              First, the data in brief:
                              Manufacturer: Lenovo
                              Model: ThinkPad L15 G3 21C3-0016GE
                              motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                              IC Bios 1: MX77L25650F
                              IC Bios 2​: MX25L25673G
                              EC Chip: NPCX997KAABX
                              So far I've been a silent reader, but now I need your help
                              I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                              I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                              The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                              01-18-2025, 02:39 AM
                            • c.daniel
                              Lenovo V310-15IKB weird bios problem...
                              by c.daniel
                              Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                              sn LR09493E
                              MB DAOLV6MB6F0 REV. F
                              The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                              Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                              Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                              08-22-2025, 05:39 AM
                            • Kei.Kurono.931
                              Lenovo Thinkpad W541 Shutdowns after bios flash (removing BAP)
                              by Kei.Kurono.931
                              Hi. I have a Thinkpad W541 that i was trying to remove the Bios Supervisor Password using this guide. https://www.badcaps.net/forum/showthread.php?t=87588 LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
                              I have the old bios backup but when i restored the original bios the laptop shutdowns after a few seconds and can´t load Windows.
                              - Using a CH134a + SOIC 8 Clip + Colibri 1.0.1.61 i backed up the original bios 3 times and verified all of them were the same.
                              - Used the Lenovo Bios Auto Patcher applied the patched file to the chip and verified...
                              03-19-2021, 05:43 PM
