6830s Keyboard works only in BIOS
  • lucco85
    • Feb 2012
    • 20
    • Hrvatska
    I have 6830s damaged by thunderstroke over LAN
    Changed: SB, lan chip.
    Laptop turns on and work fine but keyboard work only in bios. Changed KB and flash bios and still without success.
    Some suggestions?
  • lord
    • May 2011
    • 319
    • Croatia
    Re: 6830s Keyboard works only in BIOS
    Did you change the keyboard kontroller?
    • lucco85
      • Feb 2012
      • 20
      • Hrvatska
      Yes, KB is changed(KBC1091-NU)
      • fddizon
        • Sep 2011
        • 555
        • Philippines
        have you tried looking under device manager?
        if it works in bios, maybe its a driver issue. try uninstalling the keyboard on device manager and restart
        and maybe you have a live linux cd that you can boot from your dvd drive to test if it will going to work under it.
        hope this helps
        • valiant007
          Comp Technician
          • Dec 2012
          • 44
          • philippines
          if it works on the bios i would suggest reformating the laptop coz it is surely a software problem, either it is a prob with the drivers or there is a conflict with another program. that would be the easiest solution, that is of course if reformating is an option.
          _________________________________________________________________
          Free Computer Service!!!!!!!!!
          If We can´t Fix the problem.
          • NotEnough
            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
            by NotEnough
            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
            What I've Tried So Far:
            • Reseated the cables.
            • Reinstalled AWCC and AlienFX services.
            • Attempted BIOS downgrade but no improvement.
            • Inspected ribbon cables for damage.
            • Explored the possibility of BIOS or
            10-19-2024, 01:34 AM
          • survivalbloke
            MS Surface Book 3 - Keyboard works only in UEFI/Linux
            by survivalbloke
            This is a very weird issue which I'm having trouble finding a common thread.
            The keyboard is registering keypresses in either the UEFI, or a live Linux USB environment - I used Ubuntu for testing. The keyboard backlight is lit.
            The keyboard is registering keypresses in Windows or any Windows-related bootable device. For example, it does not work in Hirens Recue or a Windows 11 bootable installer.
            When booted to Windows, not only is the keyboard not registering keypresses, but my USB keyboard is not either!
            USB mouse and integrated trackpad...
            07-14-2025, 03:17 PM
          • zarabota
            Acer Aspire A717-71G - problem BIOS with keyboard
            by zarabota
            I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
            However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...
            09-03-2025, 01:58 AM
          • istvanszasz99
            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
            by istvanszasz99
            Product Name: Razer Blade 15 (2022)
            Product ID: RZ09-0421
            Motherboard: CH580
            BIOS Versions I work with: 2.02 & 2.06
            Bios File Size: 32,768 KB
            Dear Forum Readers!
            I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
            I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
            The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
            !!! MY RAZER BLADE...
            11-24-2025, 05:52 PM
          • BlueNitesFire
            I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
            by BlueNitesFire
            So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
            03-08-2025, 03:49 PM
