Acer Aspire One ao532h (NAV50) - corrupt BIOS
  • G3n1us
    • Jan 2012
    • 14
    • Estonia
    The problem started out with a bad sector on the HDD which prevented Windows from working.
    Trying to boot from a recovery CD revealed, that USB booting isn't functional. Boot order, I thought. Trying to access the BIOS causes the machine to freeze.
    Next up, I tryed flashing the BIOS, hoping that overwriting the BIOS would fix the freezing. This has worked a number of times on older Acer netbooks.
    Which I failed to notice was, that it had an Insyde BIOS, which isn't strictly happy when introduced to .fd files that Acer provides. There are some utilities which convert those to different formats, but trying out one originally meant for Phoenix BIOSs made the situation even worse.
    The machine no longer boots at all, although the crisis recovery function seems to be still operational, so theres some hope, that with the proper BIOS in the proper format, this machine can yet be saved.
    Does anyone have experience with Insyde crisis recovery functions?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Acer Aspire One ao532h (NAV50) - corrupt BIOS
    This worked for me
    http://macles.blogspot.com/2008/08/a...-recovery.html
    but I don't know if it will work for you. Additionally, you may have already tried this from reading above?
    --- begin sig file ---
    --- end sig file ---
    • thesloc
      Banned
      • Dec 2011
      • 587
      Replacing the SMD bios chip should do it..if ALL else fails.
      http://www.ebay.com/itm/BIOS-CHIP-AC...f#ht_952wt_905
      • b700029
        Banned
        • Sep 2010
        • 640
        If the EEPROM has not actually failed, it's relatively simple to rewrite it using a cheap adapter and a PC with 3.3V parallel port.
        • G3n1us
          • Jan 2012
          • 14
          • Estonia
          retiredcaps,
          That procedure has worked for ZG5's and such brilliantly, but won't for the NAV50. My guess is, that the bios .fd file needs to be named correctly or the motherboard won't find it. nav50.fd as it is originally called doesn't work and I've found no way to determine the correct name either. I've tried EZH2O from Insyde to open it, but it just crashes. Other tools suggest either AA or BB for the name, which can be disregarded as missing model names in the file. So, I'm stumped.
          thesloc, b700029,
          The ebay option seems viable, since the new chip supposedly already contains the correct BIOS. Rewriting it myself is probably out of the question, since I've only had experience with a few IBM laptops and reading their supervisor passwords. This might be over my head.
          Thanks for the ideas! I'm still open to suggestions though.
          • juan.ictech@lantic.net
            • Mar 2012
            • south africa
            i can help with the Aspire One bios flash software tool from USB, if the laptop is complete dead
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Hi - a bit out of my depth but I understand some of the words and recently managed to recover a bios on a shuttle cube using a floppy disk!!!.
              Is this the manual for the machine?:
              If so On page 144 there is a Bios recovery by crisis disk section which mentions a file name of KAV60.FD which sounds like something you have not tried.
              Anyway you can read it and it may help.
              • elreaver
                • Jun 2012
                I came across this thread in an effort to find a fix for my own Ao532h.
                I've google'd several methods to get a resolution, but no avail.
                I was in the process of a windows patch, when my system powered off.
                In an attempt to power it back on, I get nothing but a brief blue lcd of the system trying to turn on.
                I have attempted to reload the NAV50 bios from USB, but the USB stick blinks a few times, then nothing - then blinks again. Like it is trying to read it, but nothing.
                Tried renaming the bios file to KAV60.fd, but same thing.
                Tried a Win98 boot from the USB, but it will not load from that.
                Also tried the crisis from USB, but will not load that either. (I downloaded a copy off the net) I do not have the original recovery disk(s).
                I was wondering if anyone found a good solution or alternative to get the bios reloaded.
                • elreaver
                  • Jun 2012
                  I would assume that replacing this bios chip would involve removing the old one and soldering the new one in correct?
                  • thesloc
                    Banned
                    • Dec 2011
                    • 587
                    That is correct.
                    Procedure takes practice (and a hot air gun).
                    • G3n1us
                      • Jan 2012
                      • 14
                      • Estonia
                      elreaver, I doubt you'll ever read this, but rythmic blinking like that means that the machine isn't seeing the correct BIOS file. Probably a naming issue.
                      As for the matter at hand, no success on my part. The machine is comfortably sitting in the "i'll get back to it" pile for now.
                      • joshnz
                        • Feb 2011
                        • 969
                        • New Zealand
                        Your bios wasn't corrupted what u are saying sounds more like a blue screen of death from windows.
                        My pc
                        CPU : AMD PHENOM II x4 @ 3.5Ghz
                        MB : ASUS M4A89TD PRO USB3
                        RAM : Kingston ValueRAM 16gb DDR3
                        PSU : Cooler Master 850W Silent Pro
                        GPU : ATI Radeon HD 6850
                        • Spike091511
                          • Mar 2013
                          OFF the subject a little
                          I just traded for an acer one nav50 and everything worked fine while testing it, but later on that day the screen decided to give me problems with screen flickers!?!?!? What can be causing this? i was told the resolutions tried lowering them, didnt help. i was told graphics car was toast. (well if it does it sometimes doesnt that mean its not the problem?) it does it usually with start up or when on the web.
                          Any help would be apriciated thanks.
                          • simsan
                            • Oct 2013
                            • usa
                            HI gang,
                            have Acer Aspire One, NAV50, AO532h netbook, 1 GB ram - does not power ON. When charging, teh light is ON. When power button pressed, it whirrs and makes a Startup fan noise and in 2-3 seconds, the noise is gone and No power up happens. Pls. advice, with sincere thanks, best - sim.
                            • spleenharvester
                              • Mar 2010
                              • 914
                              Just to add, I've had Insyde based notebooks before that have been completely killed after a corrupt BIOS flash, to the point not even an SPI chip replacement will fix it. So if the fix posted earlier doesn't work, chances are nothing else will.
                              Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                              • EbrahimSiami
                                Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                by EbrahimSiami
                                I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                **What I have tried so far:**
                                1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                07-02-2025, 02:31 PM
                                ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-12-2024, 03:28 PM
                                ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-12-2024, 02:30 PM
                                ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
