here my dump
need bios for HP 13-BB0004NL
Re: need bios for HP 13-BB0004NL
Please read the updated rules,all bios requests must now include the full laptop model number and serial number.
You can find the right bios easily enough using Vesko`s guides,what remains then is to copy your DMI (serial number,feature byte,win key etc) to the new bios
https://www.badcaps.net/forum/showthread.php?t=122195
[Guide] How to extract ready for programming dump from HP update executable file
https://www.badcaps.net/forum/showthread.php?t=121948
.Last edited by SMDFlea; 11-15-2023, 06:23 AM. -
The BID in your backup is BID087C8
The DMI is at offsets 500000 - 50103F
.Comment
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
