Asus FX506-LU Bios
  • tracker1
    • Jul 2017
    • 122
    • romania
    Asus FX506-LU Bios
    Hi.
    I need bios dump for Asus FX506-LU
    Mainboard: DABKXFMBAC0 REV C
    Laptop power on, no display.
    Original dump attached
    Thank you!
    • 22293
    Re: Asus FX506-LU Bios
    Originally posted by tracker1
    Hi.
    Thank you!
    Please read the updated rules and post the laptop serial number.
    • ahkh_72
      • Dec 2014
      • 111
      • Iran
      hi . a customer brought me a laptop and said that after a week of turning it on, there was no image
      i upload org bios dump from board.(According to the China label, this board has already been replaced.)
      i cant find right bios file.
      any help appreciated.
      ASUS FX506LU
      SN:L6NRCX00P64523A
      MB DABKXFMBAC0 REV C
      Thanks.
      .Today should be different from yesterday.
        • 22293
        ASUS FX506LU
        SN:L6NRCX00P64523A
        Thanks.
        Post a picture of the QR code next to the CPU.
        • ahkh_72
          • Dec 2014
          • 111
          • Iran
          here
          • hoaca388
            Badcaps
            • Jan 2022
            • 12441
            here
            FX506LU
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
