Gateway N14TB REV 1.1 please share me bios
  • ruletero
    • Nov 2018
    • 182
    • Mexico
    Hi everyone
    Please your help, someone has the bios please? No video
    Gateway GWTN141-10SL
    Mobo: N14TB REV 1.1
    attached original bios
    Thanks!
    • 20909
    Re: Gateway N14TB REV 1.1 please share me bios
    Originally posted by ruletero
    Hi everyone
    Mobo: N14TB REV 1.1
    Thanks!
    Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
    • ruletero
      • Nov 2018
      • 182
      • Mexico
      Hi
      Brand: Gateway
      Model: GWTN141-10SL
      Board model: N14TB REV 1.1
      Issue: turn on without video, I don't know the root cause.
      P/N: BL.9ESAG.253
      Core i5 11th
      • volinakis
        • Jan 2021
        • 2733
        • N/A
        Hi
        Brand: Gateway
        Model: GWTN141-10SL
        P/N: BL.9ESAG.253
        Core i5 11th
        try.
        • ruletero
          • Nov 2018
          • 182
          • Mexico
          Originally posted by volinakis
          try.
          Didn't work friend, the same, turn without video.
          very thanks
          • ruletero
            • Nov 2018
            • 182
            • Mexico
            Someone can help me? Someone has bios?
            thanks
            • qayyum786
              • Aug 2018
              • 1933
              • INDIA
              someone can help me? Someone has bios?
              try
              • ruletero
                • Nov 2018
                • 182
                • Mexico
                Originally posted by qayyum786
                try
                Thanks friend but not luck, it didn't work, maybe could be another issue but there isn't many bios here to probe.
                • sanjiv16
                  • Jul 2013
                  • 43
                  • philippines
                  can someone help me removed bios password.thanks Godbless
                  gateway n14tb rev 1.1
                • peste
                  • Dec 2016
                  • 12811
                  • ROMANIA
                  read the rules..https://www.badcaps.net/forum/troubl...before-posting
                  post the S/N,the full name and model of the laptop,etc
                  • mhdted
                    LaptopMarket
                    • Nov 2023
                    • 14
                    • Iran
                    test ok
                    • cdwayne foremost
                      • Mar 2015
                      • 20
                      • jamaica
                      Originally posted by mhdted
                      test ok
                      works perfectly for me
                      • playtech17
                        • May 2025
                        • 4
                        I have recently made a huge mistake using Intel FPT to flash a bios with an older microcode (I used UBU to replace microcodes) just to see if I can unlock undervolting, and the laptop failed to post. I have a CH341a programmer and flashed a couple of similar bios to no avail. I am wondering if someone has a 1:1 copy of my laptop's bios available. That would be very helpful thanks!
                        What I need: GPU Company LC-BI-14-N14TBR100-607-H (03/30/2021) <<<<<<<
                        Model: GWTN141-10SL
                        Motherboard: N14TB REV 1.1
                        CPU: i5-1135g7
                        RAM: 16GB LPDDR4 3200MHZ
                        Bios Chip: WINBOND 25Q128JVSQ
                        Software used: NeoProgrammer V2.2.0.10
                        I'll attach two bios files
                        1. afuwin.rar (Is ONLY the bios file backed up from ami afu, it is not the whole thing but it is the original)
                        2. Brokenbios.rar (Is afuwin but backed up from neoprogrammer in full - 16mb)
                          SMDFlea commented
                          Editing a comment
                          Thread merged.
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • Vesko356
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • DynaxSC
                        by DynaxSC
                        06-14-2024, 03:49 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • AppleLover123
                        Acer Aspire A315-56-37qb mobo fried after programmed bios
                        by AppleLover123
                        Hello guys,
                        i've got this Laptop from ebay the bios was bricked. I bought it a few weeks ago and flashed it with
                        a CH341A Programmer first (Bios.bin attached) all that went good my bios worked and it booted up afterwards.
                        Now i used it and wanted more memory so i went from a 4 GB 1Rx16 to a 16GB 1Rx8 .
                        But it wont boot up with the new ram stick that i checked before in another laptop then i thought it was a good idea to flash the bios again
                        with the same .bin so i dissasembled the laptop and took out the mobo and flashed the bios again (same way i did it before)...
                        11-09-2024, 05:42 AM
