Getac B300 G5 Bios Password
  • Ole82
    • Jan 2023
    • 6
    • Uk
    Hello Everyone.
    Need Help From Knowing People, Who Can Generate Bios Password For Locked Laptop: Getac B300 G5.
    It Give 3 Try For Enter Correct Password And Hint For Unlock Key.
    As I Can See, There Is Persons In The Net, Who Can Give Generated Key For Bios.
    I Have Add Screen With This Number:
    Thanks For Help!
    Serial Number: RE763B0401
    • 22283
    Re: Getac B300 G5 Bios Password
    Originally posted by Ole82
    Hello Everyone.
    Thanks For Help!
    You must post the laptop serial number,as per the rules .
    Also,bios requests go in a seperate sub forum.Your thread has been moved.
    Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
    • Ole82
      • Jan 2023
      • 6
      • Uk
      Sorry, SMDFlea
      SN added.
      Thank You
      • AndreiKenig
        • Apr 2022
        • 4
        • Russia
        Hello ! I need password for my laptop bios.
        Model Getac B300G5
        Serial Number RE763B0401
        Thank you in advance for your help. Best regards, Andrey
        Badcaps Electronics Repair Forum & Schematic Search
          • 22283
          Model Getac B300G5
          Thread merged. Please attach files directly to your post in a zip or rar.
          • AndreiKenig
            • Apr 2022
            • 4
            • Russia
            Getac B300G5 Bios Dump
            • minhdigital
              • Nov 2022
              • 766
              • Vietnam
              Send to you
              • AndreiKenig
                • Apr 2022
                • 4
                • Russia
                Thank you very much for the work done. The laptop works, there is no password anymore
                • tracydjman
                  OG Member
                  • Jul 2013
                  • 4
                  Hello, I’m struggling to get past supervisor password on this laptop as well. Thanks!
                  SN: RGA51B0222
                  • peste
                    • Dec 2016
                    • 13924
                    • ROMANIA
                    SN: RGA51B0222
                    post S/N, full name and model, motherboard modelpost the original contents of the bios chip..
                    ,etc.
                    • tracydjman
                      OG Member
                      • Jul 2013
                      • 4
                      SN: RGA51B0222
                      Make: Getac
                      Model : B300G5
                      SN: RGA51B0222
                      Chipset: Haswell Rev. 06
                      Southbridge: QM87 Rev. C2
                      BIOS: Phoenix Technologies Ltd.
                      Version: R4.05.010600
                      Date: 08/29/2016
                      • tracydjman
                        OG Member
                        • Jul 2013
                        • 4
                        Lets try this instead of the CPUz dump
                        • The_Wang
                          • Sep 2025
                          • 3
                          Hi guys, I need a BIOS password like everyone else who buys a used Getac and support is giving me the runaround unless I give them $200+.
                          It's a B300G5
                          Serial number on the Getac label is cut out/removed but there are 2 others: 2508-504058 & RF739B0396
                          number under the Data matrix code: 2428628A0002
                          Qm87 chipset
                          Intel HD4600
                          i5-4300M
                          • peste
                            • Dec 2016
                            • 13924
                            • ROMANIA
                            It's a B300G5
                            Qm87 chipset
                            Intel HD4600
                            i5-4300M
                            • tracydjman
                              OG Member
                              • Jul 2013
                              • 4
                              peste
                              Do you need this pulled with a CH341A? Just to verify, the software pull earlier won't work? Thanks!
                              • The_Wang
                                • Sep 2025
                                • 3
                                What do I need to get the contents? One of the EePROM things?
                                • peste
                                  • Dec 2016
                                  • 13924
                                  • ROMANIA
                                  The bios chip must be unsoldered from the board before writing or reading..
                                  do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                  solder wires between the programmer and the bios chip..
                                  you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                  • The_Wang
                                    • Sep 2025
                                    • 3
                                    Thanks for the information, I assumed you could expose the chip without dismantling the laptop which I assume you have to do in removing the board to unsolder the chip and just use the scissor clip to read the BIOS that way. This is a longer process that I thought, I'll post on here again as soon as I can do that. Unfortunately last year I misplaced my soldering station after a move and don't have a great setup for working on stuff at the moment.
                                    Again, thanks a lot I might've made a huge mistake otherwise and rushed through the process
