Asus bios dump X415JA R4.2
  • tkotaleski
    • Apr 2022
    • 3
    • Macedonia
    Can someone help me, I need bios dump for ASUS F515JA, and the mainboard is X415JA R4.2
    Thanks a lot
    • 22093
    Re: Asus bios dump X415JA R4.2
    Thanks a lot
    You MUST:
    • mcckds
      • Dec 2013
      • 14
      • indonesia
      Hello everyone...
      need help... bios asus x415ja r4.2
      Attachment : original bios...no display
        SMDFlea commented
        Editing a comment
        Please read post 2 .Post the serial number,and bios backup.
    • mcckds
      • Dec 2013
      • 14
      • indonesia
      Serial number and bios backup... x415ja r4.2
      • Vesko356
        Vesko356 commented
        Editing a comment
        The serial number, make, full model number, motherboard model and revision must be written at your request as per the rules. Not as a picture, part of the file name and so on. Next time make sure to do it as it should to avoid unnecessary clarifications and wasting of time please.
    • mcckds
      • Dec 2013
      • 14
      • indonesia
      Thank you ...Vesko356
      Asus model A416J ( A416JA0 - FHD325)
      SN : N7N0CXD6V10829A
      Motherboard : x415ja r4.2.
      Please help... is no display
      bios backup : post #4
      • citylaptop
        • Mar 2022
        • 41
        • nepal
        Model- Asus X515JA-EJ592WS(X515JA)
        Serial no.-N8N0CX00E921316
        Motherboard Part No.-X415JA R4.2
        Problem-No Display
        plz help
        • citylaptop
          • Mar 2022
          • 41
          • nepal
          hellow sir i have posted #6 any update??
          • LBTT1121
            • Nov 2024
            • 1185
            • Việt Nam
            Problem-No Display
            plz help
            Hi, Try and Feedback
            • citylaptop
              • Mar 2022
              • 41
              • nepal
              thank you but still no display
              • giya
                • Apr 2020
                • 50
                • indonesia
                BIOS TESTED FOR X415JA REV 4.2
                • goldsink478
                  • Feb 2013
                  • 17
                  • indonesia
                  what the meaning JOSS GANDOS?
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
