HP 15-DW Series Bios needed
  • Semanza
    • Apr 2025
    • 18
    • Uganda
    upload failed. you are no allowed to upload files with the extension bin
      • 21339
      zip or rar
      • Semanza
        • Apr 2025
        • 18
        • Uganda
        smdea thanks it has accepted
        • peste
          • Dec 2016
          • 13079
          • ROMANIA
          can someone help fix my corrupt bios up there please
          the bios is corrupt...read the chip that posts again...
          The bios chip must be unsoldered from the board before writing or reading..
          do not use the clip, you may have errors..if you do not have anything to unsolder it with,
          solder wires between the programmer and the bios chip..
          here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
          • m1ch43lzm
            • Mar 2019
            • 568
            • Peru
            Your BIOS dump is completely corrupt, try reading it again, check your programmer settings/connection
            If possible desolder BIOS chip from the board and try again
            I cannot extract BID or S/N to find the proper BIOS
            • Semanza
              • Apr 2025
              • 18
              • Uganda
              #26
              ok thank let me read it again
              • Semanza
                • Apr 2025
                • 18
                • Uganda
                #27
                here is file again its what i have
                  • 21339
                  Same as the last one. Are you using a clip ? .What model is your programmer, i guess an EZP**** or CH341A
                  • m1ch43lzm
                    • Mar 2019
                    • 568
                    • Peru
                    #29
                    Figured out something, it's like first byte is inverted, second byte is correct, third inverted, fourth is correct, you get the idea
                    Likely BIOS chip is faulty, or programmer error
                    I managed to extract S/N CND1375S32
                    Try this, extracted from HP website, version F.67 with "fixed" DMI data
                    HP Laptop 15-dw3045nt (4J0U6EA)
                    BID 0881D
                    DMI 500000-500FFF
                    • Semanza
                      • Apr 2025
                      • 18
                      • Uganda
                      #30
                      thanks M1CH43LZM bro it has worked for me🤣 may ALLAH bless u
                      • Kjell
                        Samsung Series 9 - BIOS issue
                        by Kjell
                        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                        08-01-2025, 09:15 AM
                      • tlindi
                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                        by tlindi
                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                        Ack
                        Ack
                        01-30-2025, 04:26 AM
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • techlab
                        HP Elite Dragonfly Bios Crashed - HELP NEEDED
                        by techlab
                        Hi Guys,
                        Looking for some help with an HP Elite Dragonfly.
                        The customer explained it was updating the BIOS, the flashing completed, but afterwards the laptop wouldn’t power back on.
                        • The laptop has no power but does take the correct voltage.
                        • It shows 5 flashes white/amber, which indicates a BIOS issue.
                        • I backed up the original BIOS to extract the feature byte etc.
                        • I then flashed the BIOS with a clean version from HP’s website, but the laptop still gives 5 white/amber flashes.
                        Just wanted to pick your brains on this — has anyone come across this before or...
                        08-29-2025, 05:29 AM
