very old IBM T22 password locked
  • tyl85
    • Nov 2020
    • 47
    • Italia
    Hi, just for fun i'm trying to get back to work a very old Pentium III , IBM ThinkPad T22 (type 2647), unfortunately it has a masterlock bios password.
    Some old laptop simply need to reset cmos or short SDA SCL, but this one doesn't have 8pin flash chip
    we have an ATMEL 24RF08CT
    How can i remove this password? Thanks in advance!
  • lint4u
    • Nov 2013
    • 119
    • lint4u
    Re: very old IBM T22 password locked
    Try to short SCL and SDA like others thinkpad
    • tyl85
      • Nov 2020
      • 47
      • Italia
      this computer doesn't have that 8pin chip, i've tried to short Pin 8 and 10 with no results
      • lint4u
        • Nov 2013
        • 119
        • lint4u
        https://www.allservice.ro/forum/viewtopic.php?t=47
        check this
        • RandoomStyle
          Gigabyte 1660 Super OC 12V Short 8pin connector
          by RandoomStyle
          Hello i got a card with 12V short, found an IC blown Q510, remove it short persist, found that the short is on 12V GPU, remove all the Mosfets and the short still there, i inject 1.5V to the line and i got 1A of consumption, nothing getting warm, this could be the GPU itself?...
          12-21-2024, 08:42 PM
        • Nopslide
          by Nopslide
          04-01-2024, 04:27 PM
        • moshu
          HP EliteBook 755 G4 bios password locked
          by moshu
          Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
          I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
          Can you please help to remove the password?
          after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
          HP EliteBook 755 G4
          ProdID: W5Q98AV
          SN: 5CG7524BY4...
          02-01-2025, 06:59 AM
        • Modify_inc
          Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
          by Modify_inc
          I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
          11-02-2021, 11:14 AM
        • Mike_Ho
          ThinkBook 13S G2 ITL password locked need Help !
          by Mike_Ho
          Dear All,
          I have one 2nd hand Thinkbook 13s G2 ITL with broken display, after replace the LCD module it show password locked ,
          Can someone please kindly help me to get back the password code or modify this BIOS Dump to clean the password.
          S/N: R912D81K
          BIOS: W25R256JV
          Thank's a Lot.
          Best Rgds,
          Mike....
          07-13-2023, 09:20 PM
