Dump Asus X1402ZA
  • husniddin
    • Jan 2017
    • 98
    • Uzbekistan
    Dump Asus X1402ZA
    Hi Guys
    I need bios for laptop Asus X1402ZA motherboard X1403ZA
    My backup bios
    Thanks.
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Dump Asus X1402ZA
    Originally posted by husniddin
    Hi Guys
    I need bios clear ME for laptop Asus X1402ZA motherboard X1403ZA
    My backup bios
    Thanks.
    Read the rules before posting:
    Become a Badcaps supporter
    Thanks to all supporters.​
    • husniddin
      • Jan 2017
      • 98
      • Uzbekistan
      Hi, Guys, I have laptop Asus X1402Za, Motherboard x1403za rev 2.1 flashing bios from vinafix.
      Laptop Worked but does not see ssd nvme
      Help me update dump bios
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • pirati
      by pirati
      10-27-2025, 04:20 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
