need bios to my laptop HP 250 G9
  • HindsIT99
    • Apr 2025
    • South Africa
    Hello i need a bios .bin file for HP 250 G9 Serial no CND3141ZCV Pprod ID 7NOM6ES#ACQ.
    Notebook was updated, after restart it went into bios update screen, switched off and then never showed anything onscreen since, it switches on but screen remains black, no sign of life on screen.
      • 21677
      post your bios backup
      • HindsIT99
        • Apr 2025
        • South Africa
        There is my corruted ios, please note this is my first time programming, i need a working bios to write on the chip to get it to work, thanks
        • Bardhi
          • Apr 2025
          • Albania
          Hi, pls need BIOS for my HP 250 G9 laptop SN: CND2312FNS, Motherboad: IPA50 LA-K203P Rev: 2.0
          I wanted to reset BIOS pass, but couldn't find any password after reading the chip (WINBOND 25R128JVSN 2214). I erased and flashed with CH341A and using AsProgrammer this file 089A0.bin (I found it extracting the exe from HP page using the guides).
          Now my laptop turns one light on for 4 sec and goes off again. Screen and fan remains off all the time. I also flashed again with my backup file below and laptop still not turning on. Also tried all bios file posted here and still the same.
          • peste
            • Dec 2016
            • 13420
            • ROMANIA
            try post #3
            https://www.badcaps.net/forum/troubl...ny#post3491987
            The bios chip must be unsoldered from the board before writing or reading..
            do not use the clip, you may have errors..if you do not have anything to unsolder it with,
            solder wires between the programmer and the bios chip..
            you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...l=ThisIsHow​
            • Bardhi
              • Apr 2025
              • Albania
              #26
              Hi peste, thanks for your reply! It took me some days to order soldering tools. I tried the file below that i found on the link you send but with the clip. 2 leds and the fan were on only 5 seconds and then all went off.
              I unsoldered it from the board and ended up with a 5 leg IC (I had no hot air and first time soldering). Is there anything to do to fix this mess, before I put it in the drawer of the things destroyed by me?
              Thank you in advance!
              • peste
                • Dec 2016
                • 13420
                • ROMANIA
                #27
                buy a new chip, stick it on and write the bios that I gave you in the link...write the chip like in the video...stick it on the programmer..
                • jackx
                  • May 2020
                  • 223
                  • casa1
                  #28
                  hello help to fix bios LA-K203P ver2
                  sn
                  CND231135W
                  • JoWed
                    Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                    by JoWed
                    Hello Community,
                    I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                    07-01-2025, 09:32 AM
                  • akwky
                    by akwky
                    Hi!
                    04-14-2025, 01:56 PM
                  • TechMark1
                    Alienware 17 Area-51m laptop BIOS dump with Winbond 25Q80DVSIG
                    by TechMark1
                    I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted. I just zipped it so I could attach it....
                    09-21-2025, 03:36 PM
                  • satheesh1131
                    American Megatrends Inc bios update for HCL ME laptop
                    by satheesh1131
                    I have a HCL ME laptop 2012 model. I need to update my bios which is American Megatrends Inc,(Current Installed Version - 211) to latest. Where can I find the bios update file or How can I download it?
                    My Laptop Details:
                    Manufacturer: HCL
                    Product Name: HCL ME Laptop
                    Version: 1.0
                    BIOS Details:
                    Vendor: American Megatrends Inc.
                    Version: 211
                    Release Date: 10/19/2012
                    Address: 0xF0000
                    Runtime Size: 64 kB
                    ROM Size: 2 MB
                    01-18-2025, 11:11 PM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
