Panasonic CF-20 no screen
  • evgenymgv
    • Sep 2014
    • 19
    • Russian Federation
    Hello, dear forum users! I have a Panasonic CF-20A0198VM. After the update, the laptop rebooted, the screen was black with no image. Disabling the BIOS battery did not help. I am attaching a BIOS backup. Thank you in advance for your help!
    • 20311
    Re: Panasonic CF-20 no screen
    Post the serial number,it should be on a sticker on the bottom cover.
    • evgenymgv
      • Sep 2014
      • 19
      Serial number: 6HKSA12465
      • evgenymgv
        • Sep 2014
        • 19
        Please share the working dump for this laptop.
        • evgenymgv
          • Sep 2014
          • 19
          Still relevant. I really need a working dump! Or information on how to collect a dump for flashing the programmer from the update from the support site. Also, it might be possible to check my dump and fix it...
            • 20311
            Try this one.
            CF-20A/B/C/D (mk1)
            Bios updated to V1.00L27 ,ME firmware to 11.8.93.4323
            If its working you might have to install the latest ME driver and EC firmware
            ME Driver: https://pc-dl.panasonic.co.jp/dl/dow...4323_inf_2.exe
            EC: https://pc-dl.panasonic.co.jp/dl/dow..._1_m195071.exe
            • evgenymgv
              • Sep 2014
              • 19
              Originally posted by SMDFlea
              Try this one.
              CF-20A/B/C/D (mk1)
              Thank you very much, the laptop came to life! Could you tell me what the problem was? And how did you manage to fix it? If you want, please send me a private message. Once again thank you very much!
                • 20311
                The problem was in the ME firmware or bios region,don`t know which one.
                • plnewton
                  • Aug 2021
                  • 10
                  Can I ask what you used to load the BIOS onto the chip?
                  I usually pull the chip and write to it in a programmer but the BIOS file atatched above is only 8MB so it must be a dump from AFUWIN or something similar
                  • evgenymgv
                    • Sep 2014
                    • 19
                    Hello. The dump is 16MB in size, but in the archive it is 8MB. This dump is intended for writing to SPI flash using a programmer. I used RT809H, for example.
                    That is, just extract the dump from the archive and simply write it with the programmer.
                    • plnewton
                      • Aug 2021
                      • 10
                      thanks for confirming
                      • gabic
                        • Feb 2014
                        • România
                        Hi , I have panasonic cf-20A5396TG with no image on display , i connect a external keyboard caps lock and num lock is working,Can you help me .Thanks.
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • Chrissygizmo
                          Panasonic TX-48CX350B backlights but white screen , blank screen
                          by Chrissygizmo
                          Hi all, I’ve got a problem I hope someone can help me fixi.
                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                          01-11-2025, 03:18 PM
                        • Alicat
                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                          by Alicat
                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                          Model number is TH-50PZ85U
                          Power comes on and the red power light stays on solid.
                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                          I also hear a few clicks.
                          I also think my parents said there was a thunderstorm and the TV failed after that.
                          Section 6 in the service manual talks about power and no screen,...
                          10-30-2024, 10:09 AM
                        • smic717394
                          by smic717394
                          07-25-2024, 10:16 AM
                        • Zelek11
                          Panasonic Plasma screen interference on left half of screen
                          by Zelek11
                          My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                          This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                          10-14-2022, 04:54 PM
