Hello, dear forum users! I have a Panasonic CF-20A0198VM. After the update, the laptop rebooted, the screen was black with no image. Disabling the BIOS battery did not help. I am attaching a BIOS backup. Thank you in advance for your help!
Panasonic CF-20 no screen
Re: Panasonic CF-20 no screen
Post the serial number,it should be on a sticker on the bottom cover.
.Badcaps relies on your donations to pay for hosting , site advertising goes nowhere near to covering these costs. If you have found my reply or post helpful please consider making a donation , thank you. -
Try this one.
CF-20A/B/C/D (mk1)
Bios updated to V1.00L27 ,ME firmware to 11.8.93.4323
If its working you might have to install the latest ME driver and EC firmware
ME Driver: https://pc-dl.panasonic.co.jp/dl/dow...4323_inf_2.exe
EC: https://pc-dl.panasonic.co.jp/dl/dow..._1_m195071.exe
.Attached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by SMDFlea; 10-12-2023, 07:43 AM.Badcaps relies on your donations to pay for hosting , site advertising goes nowhere near to covering these costs. If you have found my reply or post helpful please consider making a donation , thank you.Comment
Thank you very much, the laptop came to life! Could you tell me what the problem was? And how did you manage to fix it? If you want, please send me a private message. Once again thank you very much!Try this one.
CF-20A/B/C/D (mk1)
.Comment
The problem was in the ME firmware or bios region,don`t know which one.
Can I ask what you used to load the BIOS onto the chip?
I usually pull the chip and write to it in a programmer but the BIOS file atatched above is only 8MB so it must be a dump from AFUWIN or something similarComment
Hello. The dump is 16MB in size, but in the archive it is 8MB. This dump is intended for writing to SPI flash using a programmer. I used RT809H, for example.
That is, just extract the dump from the archive and simply write it with the programmer.Last edited by evgenymgv; 12-04-2023, 05:35 AM.Comment
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM -
by AlicatHello,
Stopped by this site trying to fix my parents Panasonic Plasma TV.
Model number is TH-50PZ85U
Power comes on and the red power light stays on solid.
Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
I also hear a few clicks.
I also think my parents said there was a thunderstorm and the TV failed after that.
Section 6 in the service manual talks about power and no screen,...10-30-2024, 10:09 AM -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... - Loading...
