Acer apire a315-57g-55jc bios corrupted
  • ilcavaliere
    • Apr 2017
    • 5
    • Cagliari
    Hello everyone, my PC has had a black screen for 2 days. The PC is the model with the GPU. I tried to follow the guide to clean it up but I'm too ignorant to solve it myself... I attach my original dump, thanks to whoever will help me
    edit: I can provide more information if needed
  • hoaca388
    Badcaps
    • Jan 2022
    • 11682
    Re: Acer apire a315-57g-55jc bios corrupted
    Serial number ? This is what you're missing.
    • ilcavaliere
      • Apr 2017
      • 5
      • Cagliari
      S/N : NXHZRET00E050103527600
      SNID: 05006638676
      I hope it's these. A thousand thanks
      • hoaca388
        Badcaps
        • Jan 2022
        • 11682
        SNID: 05006638676
        Aspire A315-57G
        Model Number: A315-57G
        • ilcavaliere
          • Apr 2017
          • 5
          • Cagliari
          Thank you so much for your time but unfortunately it doesn't work. Surely there will be another problem
          • James194zt
            Acer Nitro 50-640E Corrupted BIOS Dump
            by James194zt
            My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
            All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
            04-28-2025, 03:29 PM
          • EbrahimSiami
            Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
            by EbrahimSiami
            I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
            **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
            **What I have tried so far:**
            1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
            07-02-2025, 02:31 PM
          • TheKROCZ
            Acer IPIMB-AR R1.02A bios corrupted. Need help.
            by TheKROCZ
            Hello everyone. As the title says, my bios is corrupted. I have already checked every other possible solution like ram position and reset cmos but nothing worked. I have no idea how or why it happened. The motherboard takes hours to POST. When it does POST, it gives 1 long beep and 2 short beeps. After some scavenging on other forums, I discovered that it had something to do with video output. Not sure what else is damaged in the bios but I managed to take a dump of the bios.
            I wanted to reflash the bios chip with another dump from the net. Unfortunately, I could not find any for...
            01-25-2022, 09:44 PM
          • themosttogain
            BIOS required for Acer Apire 5 A515-47 (LA-M214P)
            by themosttogain
            Not entirely convinced a BIOS will help here yet...symptoms are with charger and battery connected I get 5 blinks of the power LED (which apparently means dead battery), but with the battery removed and after numerous attempts to drain residual power and reset the BIOS, the laptop won't turn on on mains power only either (no blinks...just completely unresponsive).
            Probably going to order a new battery just in case for some reason these only boot with a good battery connected, but all evidence I find suggests these should boot on mains power alone.
            I've saved a dump...
            09-14-2023, 08:41 AM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
