Need BIOS Asus UX3404V
  • yuliang
    • Aug 2023
    • HK
    Hi
    I need full dump of Asus zenbook 14x UX3404V.
    I was looking for this dump for all thread but I can't find.
    Please help me.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12268
    Re: Need BIOS Asus UX3404V
    Originally posted by yuliang
    Hi
    Please help me.
    — You are requesting help
    If you do not abide by the following rules, your post will be deleted.
    You MUST NOT:
    Hijack threads unrelated to your request
    Post a request in multiple threads
    Post a request multiple times
    Post in foreign (non-English) languages
    Share private contact information
    Offer payment of any kind whatsoever
    Bump your thread or post more than once every 48 hours. If you do so
    you will receive an infraction
    Post "clean me", "clear bios", "clean bios", "bios need", "clear me" or other such terms
    You MUST:
    Read BIOS guides, methods, resources and tools
    Try the method at BIOS guides, methods, resources and tools before requesting help
    Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    Use search function in case someone already answered your request
    Post under a related thread if it exists
    Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
    Name your thread with model numbers and request
    Provide a BIOS/EC dump if possible
    Attach files directly to your post instead of linking to external websites
    Post what the problem is, be specific - black screen, no boot, running slow, password.
    Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
    • yuliang
      • Aug 2023
      • HK
      ASUS zenbook 14x OLED (UX3404V)
      I have donwloaded bios from asus.com but it's not full bios.
      And I have tried ftpw.exe. It's backup 16MB bios img but it's nothing to custom, looks like fake.
      And it requires to backup by ch341a programmer but I don't want to break my laptop.
      If anyone has bios dump image, please share it.
      ASUS zenbook14x OLED 3404VA
        • 21667
        Re: ASUS zenbook 14x OLED (UX3404V)
        I have donwloaded bios from asus.com but it's not full bios.And I have tried ftpw.exe. It's backup 16MB bios img but it's nothing to custom, looks like fake.
        And it requires to backup by ch341a programmer but I don't want to break my laptop.If anyone has bios dump image, please share it.
        Thread merged. You should not be making a new thread,next time you will receive an infraction .
        Read post #2 again ! ,read all of the rules !
          • 21667
          You will not be able to flash a full bios image using software tools. The only way is with an SPI programmer.Make a backup first.
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • kodox
            Asus ExpertBook B1400CB Bios Dump Needed
            by kodox
            need original bios dump, original bios has flashed by other technician before me.
            attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
            unit info:
            Model: Asus ExpertBook B1400CBA-0711A1235U
            S/N: R6NXNZ006657238
            CN: 7F6F
            Mainboard Code: B1500CBA R2.1...
            08-16-2025, 12:20 PM
