thinkbook 14,15 g4 iap bios bin NEED
https://www.badcaps.net/donateComment
Customer feedback while updating bios the machine turned off
Please help me
device:Laptop
brand :LENOVO
Model :THINKBOOK 15 g4 iap
Board no:LA-L931P ,rev1.0
S/N: MP28T0CR
Attached FilesComment
Please help me cleanME this file. tksAttached FilesComment
tryAttached FilesComment
hi same one can help me to unlock bios lenovo thinkbook 14 here original bios and S/N MP2LZKCJAttached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
NOT DISPLAY
Lenovo Thinkbook 15 G4 IAP
S/N: MP2KF1XJ
MTM:21DJ00SUUSAttached FilesComment
ThinkBook 15 G4 IAP - Type 21DJ
Attached Files↵
Hello, could you please help me? I've set the BIOS password on my Lenovo PC and I don't remember it. Could you help me decrypt it, or should I flash my BIOS chip? I'm a novice. If you could help me, I'd really appreciate it.
Model:
LENOVO THINKBOOK 15 G4 IAP Motherboard No: LA-L931P REV 1A S/N: MP2E6NZB
BIOS Chip: XMC25RH256CX
I used the CH341a programmer and AsProgrammer 2.1.2.
The BIOS chip wasn't recognized directly, nor with the Neo Programmer software. It only detected: SPI: 204319
But in the direct chip search, I managed to read it by entering the chip model: XM25RH256C at 3.3 volts
without the 1.8v adapter. I'm attaching the reading dump and I look forward to your help, please, thank you.Attached FilesComment
Model:
without the 1.8v adapter. I'm attaching the reading dump and I look forward to your help, please, thank you.Attached Files↵
Try this new version : JFCN51WW
Clean me : (16.1.32.2418)Attached FilesLast edited by lapfix; 06-06-2025, 11:15 AM.Comment
Hi, thank you very much Lapfix, I have tried your image, I have saved it and it turns out that now the PC does not boot; I press the power button, the power LED lights up but in a few seconds it turns off and no longer shows an image or the logo or anything; it has died, oh my god !!, I have saved the original image from the dump I made the first time again but it does not work either; it does not show an image or enter the BIOS or anything at all... please help me, now I am desperate because nothing works for me and I do not know why my original dump does not work either, what has happened to me? Please help me!!Comment
Please can someone help me? I have a black screen, the PC does not start, does not boot, does not enter the BIOS, and it does not work even when I flash my original dump again, it is something that I do not understand because both my CH341a programmer and the As Programmer and the connection cable between both work correctly, the problem I had when flashing the image that the user lapfix provided me, from flashing that image, I have a black screen, even when flashing my original dump, please help 1, my PC has died, please!Comment
by AhariHi all,
I...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maciek1221Hello, I'm Looking MP2964R dump in laptop Lenovo Thinkbook 16 G6 IRL, marking on the motherboard is:
ThinkBook 16 Gen6
223147-1.
448-0TF06.001
On motherboard are:
procesor - SRMLX Intel Core i5-1335U
KBC - Nuvoton NPCE48ALA1DX
BIOS - Winbond 25R256JVEN
MTM:21KHS00P00
S/N: PW08Q287
Old MP2964R is burned after water spill.
Have a nice day-
- Loading...
