Need help with corrupted E14 Gen 2 20TA(Intel) BIOS. The computer only flashes keyboard backlight quickly and then turns off.
ThinkPad E14 Gen2 20TA corrupted BIOS
This topic is closed.
Re: ThinkPad E14 Gen2 20TA corrupted BIOS
Next time read the rules before posting. Make sure your request meet the rules or you will receive an infraction.
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758)
- Name your thread with model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password.
Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
Thread closed.----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
by azozexdhello freind can you help me to repair a corrupted bios please
LENOVO ThinkPad X13 YOGA GEN2 LLX-1 MB 203015-1 448.0MC05.0011
the bios work but it showing me region recovery and it start recovering but after finish it say failed to recovery and its restarting withe the same error
seriel number:: R914W7AV
TYPE::20W8-003JFR...-
Channel: BIOS Requests ONLY!
by trepachkaHello, I have this ThinkPad P1 Gen 4 that has what I perceive corrupted bios. Computer charges and upon pressing the power button, the keyboard lights up briefly, both fans begin to spin and the cpu gets warm. However, I get no post. I do get color palette cycling all sorts of colors on the screen when I press Fn-Cntrl-Power key combo at the same time (standard Lenovo screen test). So, this tells me the issue is with bios. All voltages are present including CPU, GPU and memory voltages.
The bios file is a little tricky. I believe it has 2 identical 256Mb chips next to each other (photo...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by Loki_FidoHi everyone, hope everyone's having a great day.
I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
Does this mean the BIOS is fine? making it a hardware issue?
I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...-
- Loading...
