need BIOS for ASUS Zephyrus GA503RM
Hi everyone, I’m experiencing the same issue. From what I found online, it seems to be a common problem. I have an Asus GA503RM laptop, SN: N6NRCX097405256. If I roll back the BIOS to version 313 or 315, everything works fine. But after updating to 317 or higher, I get a black screen issue.
Can you help? Or is it possible to lock my original BIOS dump so it doesn't get updated from within Windows?
post motherboard model,Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
Channel: BIOS Requests ONLY!
by skipron.rmHello everyone, trust you're doing well.
I'm currently facing an issue with my ASUS Zephyrus GX701LXS, as it isn't posting.
I've downloaded the latest BIOS version, "GX701LXS-AS.311" (v.311), from the ASUS website.
However, there's a challenge – the file size exceeds the capacity of the BIOS chip, making it impractical for writing.
The current BIOS dump ("GX701LXS.307 bios-dump.bin" find attached), is of version 307.
My attempt to extract "GX701LXS-AS.311" using the "AMI_BIOS_GUARD_Extractor" was aimed at combining...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by skurvysynHello,
laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...-
- Loading...
