Need Bios dump Asus ROG G17 G713RC
  • FreshZero
    • Aug 2023
    Hey,
    i need a dump for the ROG G713RC-HX032W.
    the search only shows up other models.
    Pleas i need help
  • peste
    • 13132
    • ROMANIA
    Re: Need Bios dump Asus ROG G17 G713RC
    Originally posted by FreshZero
    Hey,
    i need a dump for the ROG G713RC.
    Pleas i need help
    read this...
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • kodox
      Asus ExpertBook B1400CB Bios Dump Needed
      by kodox
      need original bios dump, original bios has flashed by other technician before me.
      attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
      unit info:
      Model: Asus ExpertBook B1400CBA-0711A1235U
      S/N: R6NXNZ006657238
      CN: 7F6F
      Mainboard Code: B1500CBA R2.1...
      08-16-2025, 12:20 PM
