lenovo thinkbook 15 g2 itl disable onboad ram bios
  • deejay_xb
    • Aug 2023
    • 8
    • Romania
    I have a lenovo thinkbook 15 g2 itl (working!) and in the .bin bios file i found the lines with 6.5.6.5...6, but i don't know what to replace with 00 to disable the onboard ram/memory, if someone can help.
    i've attached the extracted .exe file, this contains the bios dump when opened with 7zip (the file is DOSFLV34_QS.bin)
    also how to flash the modified bios? can it be repacked and flashed?
  • Ghamidi
    • Mar 2020
    • 306
    • France
    Re: lenovo thinkbook 15 g2 itl disable onboad ram bios
    upload your bios backup
    • deejay_xb
      • Aug 2023
      • 8
      • Romania
      this is the extracted bios
      • Ghamidi
        • Mar 2020
        • 306
        • France
        orginal bios file
        • deejay_xb
          • Aug 2023
          • 8
          • Romania
          can you tell me how to get the bios file?
          edit: i have extracted the bios from the previous file, now it's unsigned
          • Ghamidi
            • Mar 2020
            • 306
            • France
            https://www.youtube.com/watch?v=J8-Sh7DjiXw
            • deejay_xb
              • Aug 2023
              • 8
              • Romania
              the laptop is working, can i dump the bios from windows/dos or something?
              • deejay_xb
                • Aug 2023
                • 8
                • Romania
                where is the bios chip location on the mb?
                • deejay_xb
                  • Aug 2023
                  • 8
                  • Romania
                  here is the 16MB bios, please guide me what to replace to disable the on board ram
                  • peste
                    • Dec 2016
                    • 14052
                    • ROMANIA
                    try..
                    • nikovmiroslav
                      • Oct 2010
                      • 39
                      Hi, I have Lenovo thinkbook 15 g2 itl,i think Bios is not good,it turns on but without picture,is there anyone who can help with new bios and I would like to Disable onboard Ram through bios? Thank you!
                      FLV35 LA K052P REV 1.0
                      S/N MP23P95S
                      MTM 20VE005BYA
                        • 22424
                        S/N MP23P95S
                        MTM 20VE005BYA
                        Your backups aren`t good. Are you using a clip. What model is your programmer and software version
                        • nikovmiroslav
                          • Oct 2010
                          • 39
                          I'm not using clip,using CH341 and NeoSoftware V2.2.0.8, i also saw that something is not good with the dumps but never had problem with CH341 and Neo
                          Maybe something Happened with programmer,can you try now?
                          • nikovmiroslav
                            • Oct 2010
                            • 39
                            I tried again,can you saw now?
                            • Stefan Steff
                              • Mar 2024
                              • 421
                              • Romania
                              Still not good...
                              "FfsParser::parse: not a single Volume Top File is found, the image may be corrupted"
                              Your dump will be good when at address 0x0099E210 you will have something like this:
                              Click image for larger version  Name:	image.png Views:	0 Size:	3.2 KB ID:	3450543
                              • nikovmiroslav
                                • Oct 2010
                                • 39
                                Originally posted by Stefan Steff
                                Still not good...
                                Thank you,probably the dump is corrupted,i found the dump that works and onboard ram is disabled,but it has no serial number and didn't recognize my SSD disk at all,if you can rebuild this dump i will be grateful.
                                Serial number is: MP23P95S
                                • nikovmiroslav
                                  • Oct 2010
                                  • 39
                                  I resolve ssd problem with returning old 8mb dump,can you just properly disable onboard ram on dump above because it is not good? Thank you
                                    • 22424
                                    Your files are too corrupt to repair or get any DMI or key from.
                                    Try these.
                                    • nikovmiroslav
                                      • Oct 2010
                                      • 39
                                      Try these.
                                      Thanks i tried but now turns on with black screen and restarts every 10 second,yes my old dumps are very corrupted,is there any chance to fix this problem?
                                        • 22424
                                        Did you flash the 8MB and the RAM disabled version
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • HumanDev228
                                          Lenovo ThinkBook 13s Gen 3 ACN – Need Help Fixing Corrupted BIOS (W74M12JW)
                                          by HumanDev228
                                          I’m working on a Lenovo ThinkBook 13s Gen 3 ACN (AMD Ryzen 5 5600U) with a Winbond W74M12JW 16MB BIOS chip
                                          Symptoms:
                                          • No display, fan spins, white LED blinking
                                          • Temporary boot after flashing another BIOS
                                          • Dies again after reboot
                                          • Current BIOS dump appears corrupted (mostly FF-filled, no valid UEFI structure)
                                          What I already tried:
                                          • External flash with CH341A + proper 1.8V supply
                                          • Flashed GMCN33WW-031F.bin (booted once, then failed again)
                                          • Reflashed original dump → same issue
                                          • Power reset, battery disconnect
                                          • RAM reflow attempt (no change)
                                          12-08-2025, 05:25 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • HotSaladMan
                                          Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                                          by HotSaladMan
                                          *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                                          Model : Lenovo ThinkBook 14S Yoga ITL
                                          S/N : MP28JT19
                                          MFG Date : 2022/02/09
                                          Factory ID PRC4
                                          MO : MPNXB26080FX
                                          MTM : 20WE001US
                                          MODULE FCC ID : PD9AX201NG
                                          IC : 1000M-AX201NG
                                          BOARD INFO
                                          FLV34 LA-KO51P
                                          REV : 1B 2020-08-24
                                          Bit of Info
                                          Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                                          chip id, so i would always uncheck the id check, so it would bypass the error
                                          i did in fact make...
                                          11-07-2024, 07:46 AM
                                        • TecnicaNTT
                                          Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                                          by TecnicaNTT
                                          I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                                          My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                                          I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                                          I am now asking here for help if anyone knows how to do this in...
                                          09-20-2024, 08:10 AM
