SN:CND1200FVC
HP 250 G8 bios password
Tags: None
HP 250 G8 bios Admin password Remove
S/N CND1113FBNAttached Filesif you find these attachements useful please consider making a small donation to the site
Send to youAttached Filesif you find these attachements useful please consider making a small donation to the site
HI NEED HELP TO REMOVE BIOS PASSWORD.
MODEL: hp 250 g8
PRODID:4K804EA#ABZ
SN: CND2046WNC
BOARD NO:GPT52 LA-K201P REV 3.0Attached Filesif you find these attachements useful please consider making a small donation to the site
Find and extract a virgin bios, copy your DMI to it,flash the bios, password gone.
https://www.badcaps.net/forum/troubl...flash?t=122195
[Guide] How to extract ready for programming dump from HP update executable file
https://www.badcaps.net/forum/troubl...-file?t=121948
DMI 500000 - 50103F
.Comment
read the rules..https://www.badcaps.net/forum/troubl...before-posting
post the original bios of the laptop, the motherboard model, the full name and model of the laptop,
etc.
Every donation made will go towards server fees and maintenance costs.Comment
HP 250 G8 LA-k201P
Serial: CND1180ZTL
please clear my bios password.
thanks everyoneAttached Filesif you find these attachements useful please consider making a small donation to the site
Good afternoon, can you remove the password?
HP 250 G8
SN BRJ2514MY5
BOARD. LA-K201P REV1.0 2020-09-18Attached Filesif you find these attachements useful please consider making a small donation to the site
Good luckAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi the history is the user has broken the hinges and screen but no damage visiblr to the LCD cable.
it was left for a couple of days and the battery discharged, after charging the screen backlight no longer worked.
Replaced the complete lid assy, guaranteed working backlight, stil the same problem on the EDP connector of the mobo the backlight enable line always stays low.
I assume it is BIOS error, i tried crissis recovery with ext screen and it completed ok but still the same problem.
I am asking if anyone has a good file dump or can create one with my info.
The TXT file is the current BIOS dump using a dataman programmer in bin format.
This is my 1st post so please be gentle and guide me where I have erred.
RichAttached Filesif you find these attachements useful please consider making a small donation to the site
post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
Don't post pictures unless asked....No one wastes time enlarging pictures, turning them, or using a magnifying glass to see numbers or letters..
it makes our work easier, not yours..
read the forum rules..
post S/N, full name and model, motherboard model, product number,etc....write with the keyboard..Hi the history is the user has broken the hinges and screen but no damage visiblr to the LCD cable.
Rich
post the contents of the bios chip even if it is corrupted..
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
Hi Peste
Thankyou for your response, I did browse the poster hints but obviously not good enough, some forums don't like appending onto other posters questions so I wrongly started my own.
The Laptop is an
HP 250 G8
Product No 2M3A1ES#ABU
SN CND13124J2
Mobo FPI50 LA-H329P Rev 2.0
The problem is no LCD backlight enable signal from the mobo the LCD old screen has broken hinges, it did illuminate but no longer does and the only thing that as far as I know was the battery fully discharged before I got it and after recharge the screen no longer illuminated.
I replaced the whole lid assy any way just incase the cable had been damaged with a known good screen assy, this also shows a picture on the screen but no LCD back light operation and again the back light enable signal on the EDP connector on the mobo remains low.
I have attached the BIOS file from the computer I have renamed the ext to TXT as the site says I can not upload .bin files.
Please advise.
Richard
HP 250 G8 Notebook PC (2M3A1ES)Hi Peste
The Laptop is an
HP 250 G8
SN CND13124J2
Please advise.
Richard
Use Winrar or 7zip before posting.Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
Channel: BIOS Requests ONLY!
by fx1982Hi everyone, can someone please help to remove bios Administrator password or decode as I failed miserably... Tried reading the password but it says wrong password. Thank you in advance!
It's a 2024 Asus Zephyrus G16
GU605MV
SN: S2NRCX035924088
CN: AEDW
MFD: 2024-02 36M
BIOS VERSION: 315...-
by PhadDear All,
Hope that this post is at the right place of the forum.
I am seeking help and technical advice to remove bios admin password from HP ProBook 4520s.
The laptop is operating normally and, I am not facing any major issue with it except; the bios admin password that I found about by coincidence only few weeks back.
As the laptop is operating normally, I am reluctant to take it to a workshop to de-solder the bios chip in order to read it by an external programmer, as I am not an expert in doing such a thing.
After...-
by CuteWildCatHello there,
My Dell Optiplex 3090 bios is locked with admin password. Worst of all, it seems.
Here is my system number 1THQMS3-8FC8.
I don't have the hardware to dump my bios, and I can't pay 400€ to hope to get a password from a guy I don't even know exists. So without conviction I'm wondering if anyone here can help me.
Thank you in advance...-
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
- Loading...
