Asus fx705dt clean bios me region amd
  • Safio
    • Jun 2017
    • 46
    Hello Folks,
    looking for clean bios me region for asus FX705DT Model with AMD ryzen cpu
    please help
    thank you
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Asus fx705dt clean bios me region amd
    Originally posted by Safio
    Hello Folks,
    please help
    thank you
    AMD cpu equipped machines doesn't have "me region" (ME firmware) in the bios.
    Read the rules, describe what the problem is, upload your bios backup and serial number.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Safio
      • Jun 2017
      • 46
      here is all info needed backup file attached
      issue: laptop boot up with black screen , fan working , keyboard backlight working everything seems working except the display , nothing has been done on the laptop such as repair or anything prior to that
      the serial number
      04D4C474C58A
      P/N 60NR02B0-MB2000 (121) FX705DT 18233392
      PT:N0CV1920MB0026560
      69N18SM10A15 (01)
      • volinakis
        • Jan 2021
        • 2878
        • N/A
        the serial number
        04D4C474C58A
        69N18SM10A15 (01)
        failed hackintosh? you did clear NVRAM, right?
        try
        • Safio
          • Jun 2017
          • 46
          thank you for the tip however its not Failed Hackintosh unfortunately also yes i did clear the nvram once and didnt fix the issue
          • Safio
            • Jun 2017
            • 46
            also i forgot to mention that its working if i hook it up to external screen , i can use it normal i just dont have backlight , i tried new screen, new lcd cable, reflash the bios and still same, if i use flashlight i can see everything on screen just no backlight,
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              also i forgot to mention that its working if i hook it up to external screen...
              You should have started with that because then it's not a bios problem.
              • volinakis
                • Jan 2021
                • 2878
                • N/A
                check voltage on pins 27-28-29 eDP 30pins display connector, it should be 19V with AC Adapter plugged in. If no voltage it should be a fuse on motherboard corresponding to these pins, check it. I don't have schematics for this motherboard. Upload a clear picture of motherboard near display connector.
                • Safio
                  • Jun 2017
                  • 46
                  thank you for the advice y'all , so here is an update, when the laptop is off and plugged in the charger i see the 19v on the pins above but once i start it the voltage drops to 2.4v so what i did is ran a wire from a cap that has 19v straight to the LCD pins and that resolved the problem and got the backlight back however i would love to find that fuse or whatever component that is damaged, i did the the tests around the motherboard and couldn't find anything burned or not functioning properly
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
                  • lrouw84
                    Asus vivobook s510ua bios changed to x510un
                    by lrouw84
                    Hi there,
                    I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                    I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                    01-28-2023, 01:31 PM
