Originally posted by alvin dionisio
View Post
Hp elitebook 840 g9
Originally posted by alvin dionisio View Postplz help admin locked
Hp Elitebook 840 g9
SN# 5C33038K6
2) First boot will delay a few minutes
3) IMPORTANT: Go to BIOS F10 Setup and reset to Factory Default (first main page tab)
4) Restart and enter BIOS
5) 2nd boot restore security settings to defaultsAttached Files
Originally posted by essaadi View PostPlease unlock BIOS.
Originally posted by SMDFlea View Post
Read https://www.badcaps.net/forum/troubl...before-posting and post the laptop serial number
EliteBook 840 G9
SERIAL : 5CG2370GWB
THANK YOU VERY MACH
EliteBook 840 G9
SERIAL : 5CG2370GWB
2) IMPORTANT: Go to BIOS Setup ( F10 ) and reset to Factory Default (first main page tab)
3) Restart and enter BIOS
4) 2nd boot restore security settings to defaultsAttached Files
Originally posted by lapfix View Post
1) First boot will delay a few minutes
I think there is some errors in first BIOS i have upload.
the correct file is here.Attached Files
Hello every one in BADCAPS.
Here is a solution to unlock Elitebook 840 G9 :
*Make a backup of your BIOS (main).
*Flash ROM circuit with unlocked BIOS of an other 840 G9 (same motherboard model, in my case 6050A3417601-MB-A01)
*- Originally posted by lapfix View Post -
*If you have problems (MPM, late boot...) flash ROM circuit with your backup.
*Enjoy
Originally posted by EdMac View PostI need help to unlock this Bios ! I have tried different forum files but have not had any success!
EliteBook 840 G9
Board Number: 6050A3417601-MB-A01
SERIAL: BRJ352C8TM
Thank you in advance for your attention!!
Follow steps in post 272 above using joined file.
Give feedback.
Give feedback.
So, what do you suggest I do?
Originally posted by EdMac View PostThis is the error message I get! And then it restarts and no longer shows video!!
Can someone help me?? Please!!
You MUST follow this steps:
4) 2nd boot restore security settings to defaults.
Try and give Fedback
Originally posted by EdMac View PostMy brother! Thank you very much for your attention!! However, with this Bios, an error message appears and it restarts and then stays in a loop. It doesn't start!!
Give feedback.
I spent the last few days trying to unlock it! However, when I tried to remove the EC bios, I messed everything up! Some resistors moved out of place and I'm not sure about their position and their values.
Could a friend of mine send me a photo of this area (photo below) and, if possible, the value of the resistors in red.
Thank you in advance for your help!!
