Hp elitebook 840 g9
  • rex98
    • Feb 2023
    • 1293
    • Mandaue CEBU, Philippines
    #221
    i noticed there's a lot of unlock request for this model HP EliteBook 840 14 inch G9 and patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should flash both.
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU.
    • shiriff47
      • May 2018
      • 45
      • Algeria
      #222
      use BCU.
      Thank you very much it's working great the password is gone.
      i did like you said but i did't use BCU i just flash back my original bios
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        #223
        Originally posted by zzduczz
        Please unlock bios elitebook 840 g9
        SN:5CG32464T6
        write from post #220 new version is blocked by HP
        • abomochris
          • Feb 2016
          • 3
          • cameron
          #224
          please unlock bios hp elitebook 840 g9. SN : 5CG2248Z1L
          • szabi
            • Jun 2020
            • Cluj Napoca
            #225
            Hi everyone
            can someone help me with unlocking the Hp 840 G9 bios
            SN:5CG3080ZYF. THANK YOU IN ADVANCE​
            • Tosebeee
              • Aug 2023
              • 10
              • Nigeria
              #226
              good dey boss i have 840 g9 with bios password pls help clear the bios sn 5CG2371FSB MAIN AND EC FILE ATTACHED
              • rex98
                • Feb 2023
                • 1293
                #227
                read my post # 221 https://www.badcaps.net/forum/troubl...27#post3576427
                • usuario0217
                  • May 2018
                  • colombia
                  #228
                  Hello team,
                  Can some one help me unlock this bios many thanks
                  S/N: 5CG4094YZQ
                  PRODID: 7K7T0LP#ABM
                  HP ELITEBOOL 840 G9
                  • mehar
                    • Feb 2015
                    • 12
                    Need Help to Clear ME this file
                    Model: HP EliteBook 840 G9
                    Motherboard Number: 6050A3417601-MB-A01
                    S/N:5CG3026830
                    Old file Attached
                    IC Location: U367
                    Bios Ver: U71 Ver. 01.13.00
                    What I have done until now:
                    I downloaded and replaced the same version of the bios region but to no avail.
                    I tried to open it with intel mfit 16.1 but giving multiple errors.
                    • volinakis
                      • Jan 2021
                      • 2874
                      • N/A
                      #230
                      S/N:5CG3026830
                      Old file Attached
                      IC Location: U367
                      upload original bios, not one with BIOS_region replaced.
                      • Zibbo
                        • Mar 2017
                        • 205
                        • Zimbabwe
                        #231
                        S/N:5CG3026830
                        Old file Attached
                        IC Location: U367
                        Try
                        • mehar
                          • Feb 2015
                          • 12
                          It's the same old problem. The laptop draws over 600mA for 2 seconds, and the fan spins. After that, the load remains at 85mA. I need to explore a different direction.
                          Thanks a lot for responding to both of you
                          • CammyTier1
                            Tier 1 Assets
                            • May 2022
                            • 43
                            Pleasecan ssomeone unlock for me
                            sn - 5CG3172T6F
                            • Bios Cracker
                              • Oct 2024
                              • 322
                              • India
                              #234
                              Try and Feedback.
                              1) Flash Patched File
                              2) First boot will delay a few minutes
                              3) IMPORTANT: Go to BIOS Setup and reset to Factory Default (first main page tab)
                              4) Restart and enter BIOS
                              5) Write original DMI data back or flash original BIOS backup.
                              Your DMI Data.
                              Description: HP EliteBook 840 14 inch G9
                              Serial Number: 5CG3172T6F
                              Product #/SKU: 6B4Y3AV
                              Board CT Number: PQSPR00WBI0194
                              Build ID: 22WWWPBZ602#SABU#DABU
                              Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfAfPgSguhKjhk8mEn7nVngpFpTpnpqprqjqz.Tq
                              MAC Address: E0-73-E7-A5-A0-B6
                              • usuario0217
                                • May 2018
                                • colombia
                                #235
                                Originally posted by BGinvestments
                                I solved it on my own, it turns out that version u71 01.11.05 or higher retains the password, I have downgraded the version to u71 01.10.00 using an ec, and a clean bios, it works perfectly, you just have to write the dmi information later with some mpm tool.
                                Here I leave you an ec and a clean bios of that version.
                                PD. Make sure your actual bios is U71 too
                                WORKS FOR ME
                                THANKS
                                • Bios Cracker
                                  • Oct 2024
                                  • 322
                                  • India
                                  #236
                                  Did you try post 234 ?
                                  • computeka
                                    • Apr 2021
                                    • 31
                                    • colombia
                                    #237
                                    HP EliteBook 840 G9
                                    SN# 5CG2264C3Z
                                    ProdID 6W029UP#ABA
                                    MDM lock and password
                                    • volinakis
                                      • Jan 2021
                                      • 2874
                                      • N/A
                                      #238
                                      use BCU.
                                      your bios+EC is very good for 840 G9 with U70 bios family, there are also 840 G9s with U71 and U76 bios family and your bios+Ec will not work. Good job, anyway! 👍
                                      • Ghamidi
                                        • Mar 2020
                                        • 305
                                        • France
                                        #239
                                        Originally posted by computeka
                                        HP EliteBook 840 G9
                                        SN# 5CG2264C3Z
                                        ProdID 6W029UP#ABA
                                        4) Restart and enter BIOS​
                                        Please need feedback
                                        • computeka
                                          • Apr 2021
                                          • 31
                                          • colombia
                                          #240
                                          This is the patch for the EC right?
