Hp elitebook 840 g9
Please remove BIOS Administrator Password
hp Elitebook 840 G9
Build ID : 22WWWPBZ602#SABU#DABU
sn/ 5CG3124DQ4Comment
I am not 100% sure you got a good reading try saving a few more backups before reprogramming, Give the file a go I done my best.Attached FilesComment
I read it 10 times with asprogrammer and neoprogrammer and it's always the same checksum
I Writte this hp840g9front No Password.bin and the keyboard lit up and blocked everything, only three LEDs above the function keys turned on.
the laptop is stuck there
I will see on Monday to return the original binComment
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU. you can permanently disable Absolute lock in BCU.
here's your DMI:
Serial Number: 5CG3124DQ4
Product #/SKU: 6T1H6EA#ABU
CT Number: PPQBH00WBHU1H1
Description: HP EliteBook 840 14 inch G9
BuildID: 22WWWPBZ602#SABU#DABU
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfAfPguhKhkjhk8mEn7nVngpTpWpnpqprqjqz.GMAttached FilesComment
first boot press f10 apply factory defaults and restart, ..... this works, MPM ... I can also browse the BIOS menu, I couldn't before
2nd boot reset security ...... it won't, it will always ask me for the ADMIN password
I've been trying for hours
f10 and factory reset works normally ... The MPM timer always resets after that. I entered all the DMI values from the bios ....
Just reset security ...... it won't, it will always ask me for the ADMIN password..
Can someone calculate the Admin password from the bin file?Comment
hi any one help plz for unlock the bios hp elitebook 840 g9
SN 5CG3252VHKAttached FilesComment
Give this a tryAttached FilesComment
here's your DMI:
Serial Number: 5CG3252VHK
Product #/SKU: 88S79EC#ABE
CT Number: PPQBC00WBI726K
BuildID: 22WWWPBZ602#SABE#DABE
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saEapaqauawbUbhcAfPgSguhKjhk8mEn7nVngpDpFpVpnpqprqjqz.HB
MAC Address : BC:0F:F3:47:2B:C8Attached FilesComment
thank you very much it working
here's your DMI:
MAC Address : BC:0F:F3:47:2B:C8Comment
HP EliteBook 840 14 inch G9 Notebook PC
CT Number_6MBNF0CWYH78KQ
Serial_5CG2461L2C
Sku_5Z695EA#ABH
Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdpdqfAfPguhKhkjhk8mEmGn7nVngpTpppqqjqz.dD
Build Id_22WWWPAT602#SABH#DABHAttached Files↵
https://www.badcaps.net/donateComment
i have a HP elitebook 840 g9 bios password pls can any one removd password here is bios file s/n 5CG2362VDTAttached FilesComment
after following my instruction to get rid of Manufacturing mode. use BCU.
here's your DMI:
Serial Number: 5CG2362VDT
Product #/SKU: 6Z4A9UP#ABA
CT Number: PQSPN00WBH319X
BuildID: 22WWWPAT602#SABA#DABA
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdpdqfPgSguhKjhk8mEmwn7nVngpDpVpqqjqz.Eg
MAC Address : 38:CA:84:4E:59:F7Attached FilesComment
Thank s
here's your DMI:
password is removed
Can someone unlock bios for HP elitebook 840 g9?
SN# 5CG23634TLAttached FilesLast edited by maobuff; 07-25-2024, 05:12 AM.Comment
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:50 AM
- Loading...
